When I download a file for a tv show that is your standard 720p.HDTV.X264-DIMENSION .mkv 1.9GB file with AC3 CBR for audio, I can easily extract the audio file using MKVtoolnix and then split the audio file into 6 channels using another program. The audiio track the .mkv download comes with has the ability to be split into 6 channels.
My download speeds are slow so I'd rather not download something so large (1.9GB takes forever on my computer) so I was wondering if instead of the above file, if a went with the smaller (316MB) HDTV.x264-LOL .MP4 file with AAC VBR for audio, once I extract the audio using a program that does that for mp4 files.. is there really any chance the audio could be split into 6 channels or is that really rare on this type of file/download and it's prob. just going to be 2 channel audio?
Again, when I download the .mkv file with AC3 CBR audio, the audio is 6 channel, is it realistic that I'd get 6 channel audio out of the .mp4 file with AAC VBR audio or is it basically always going to be 2 channel? Thanks.
Closed Thread
AC3 File: Audio only on left channel
By koberulz in forum AudioReplies: 10Last Post: 25th May 2011, 12:07 -
How to extract each audio channel in a DAT file (from VCD)?
By coxanhvn in forum Newbie / General discussionsReplies: 9Last Post: 28th Apr 2011, 17:06 -
How to convert a trp type file to Mpeg2 type?
By Jemes-bs in forum Video ConversionReplies: 2Last Post: 13th Oct 2010, 15:59 -
Removing audio channel from dat file
By Lextar in forum Authoring (VCD/SVCD)Replies: 1Last Post: 25th Jul 2010, 22:08 -
Stereo, Joint Stereo or Dual Channel for Audio input type?
By c627627 in forum CapturingReplies: 1Last Post: 23rd Mar 2009, 09:33
