    Hi. I have a similar problem. I have an anime with DTS audio on an MKV file. I extracted the DTS audio and inserted it as the main audio on DVDLab Pro. It appears to encode it properly, but, when I play it, there is no audio. Actually, my player detects there is a DTS audio channel there, but there is no sound.
    Ps.: I don't understand the info on the log, as I'm not a programmer or developer, I just know how to create DVDs in a very amateurish way. So bear with me but am I missing some DTS encoding plug-in or something? Because I have inserted DTS files on DVDLab Pro compilations before, and they worked fine.
    Here is the project compiling log:
    4 - 11 - 2012 -- 15:50:3
    * VMG Verification *
    Number of VTS - 1
    Number of Menus: 2
    Menu 01 - Type - Dummy
    Menu 02 - Type - Motion
    Menu Video File C:\Users\ALEXANDRE\Documents\ANIME COPIED MOVIES\Howl's Moving Castle\Menus\main-0.m2v
    Frame size: 720 X 480
    Frame rate 4 [1--23.976, 2--24, 4--29.97, 3--25, 5--30]
    Aspect Ratio: 169 [43--4:3, 169--16:9]
    MPEG Video Type: 2 [1--MPEG 1, 2--MPEG 2]
    Chroma: 1 [1--4:2:0, 2--4:2:2, 3--4:4:4]
    GOP 1, size - 538246
    GOP 2, size - 165066
    GOP 3, size - 474313
    Menu Audio File C:\Users\ALEXANDRE\Documents\ANIME COPIED MOVIES\Howl's Moving Castle\Menus\main.ac3
    Audio type: AC3_Mot, Channel: 6, Sampling: 48000, Bitrate: 448000
    Menu Sub-Picture File C:\Temp\92010632_tmpsub1.bmp
    Picture size - 720 x 480
    nMenu cell count - 1
    Number of imported VTS: 0
    * VTS Verification *
    <<< VTS Number 1 >>>
    Number of Titles: 2
    Title 01 - Type - ES or PES
    Segment 1, Video File C:\Users\ALEXANDRE\Documents\ANIME COPIED MOVIES\Howl's Moving Castle\Files\Project_1\Howl's.Moving.Castle.2004.x 264.DTS.3AUDIO-WAF.m2v
    Frame Size: 720 X 480
    Frame Rate 4 [1--23.976, 2--24, 4--29.97, 3--25, 5--30]
    GOP 1, size - 16834
    GOP 2, size - 16779
    GOP 3, size - 267690
    Segment 1, Audio File : None
    Segment 1, Subtitle File C:\Users\ALEXANDRE\Documents\ANIME COPIED MOVIES\Howl's Moving Castle\Files\1.sp1
    Title 02 - Type - ES or PES
    Segment 1, Video File C:\Users\ALEXANDRE\Documents\ANIME COPIED MOVIES\Howl's Moving Castle\Menus\m0-m1.m2v
    GOP 1, size - 270925
    GOP 2, size - 312399
    Segment 1, Subtitle File : None
    Number of Menus: 11
    Menu 02 - Type - Still
    Menu Image File C:\Temp\92026336_tmp1.bmp
    Menu Sub-Picture File C:\Temp\92026336_tmpsub1.bmp
    Menu 03 - Type - Still
    Menu Image File C:\Temp\92659544_tmp1.bmp
    Menu Sub-Picture File C:\Temp\92659544_tmpsub1.bmp
    Menu 04 - Type - Still
    Menu Image File C:\Temp\112771736_tmp1.bmp
    Menu Sub-Picture File C:\Temp\112771736_tmpsub1.bmp
    Menu 05 - Type - Still
    Menu Image File C:\Temp\114489536_tmp1.bmp
    Menu Audio File C:\Users\ALEXANDRE\Documents\ANIME COPIED MOVIES\Howl's Moving Castle\Menus\setup.ac3
    Menu Sub-Picture File C:\Temp\114489536_tmpsub1.bmp
    Menu 06 - Type - Still
    Menu Image File C:\Temp\371319128_tmp1.bmp
    Menu Sub-Picture File C:\Temp\371319128_tmpsub1.bmp
    Menu 07 - Type - Motion
    Menu Video File C:\Users\ALEXANDRE\Documents\ANIME COPIED MOVIES\Howl's Moving Castle\Menus\ep1.m2v
    GOP 1, size - 228039
    GOP 2, size - 237705
    GOP 3, size - 265852
    Menu Audio File C:\Users\ALEXANDRE\Documents\ANIME COPIED MOVIES\Howl's Moving Castle\Menus\episodes.ac3
    Menu Sub-Picture File C:\Temp\297184920_tmpsub1.bmp
    Menu 08 - Type - Motion
    Menu Video File C:\Users\ALEXANDRE\Documents\ANIME COPIED MOVIES\Howl's Moving Castle\Menus\ep2.m2v
    GOP 1, size - 203935
    GOP 2, size - 188712
    GOP 3, size - 190499
    Menu Sub-Picture File C:\Temp\297190432_tmpsub1.bmp
    Menu 09 - Type - Motion
    Menu Video File C:\Users\ALEXANDRE\Documents\ANIME COPIED MOVIES\Howl's Moving Castle\Menus\transition-a.m2v
    GOP 1, size - 505635
    GOP 2, size - 246817
    GOP 3, size - 3157
    Menu Audio File C:\Users\ALEXANDRE\Documents\ANIME COPIED MOVIES\Howl's Moving Castle\Menus\transiton-a.ac3
    Audio type: AC3_Mot, Channel: 2, Sampling: 48000, Bitrate: 256000
    Menu Sub-Picture File C:\Temp\414968696_tmpsub1.bmp
    Menu 10 - Type - Motion
    Menu Video File C:\Users\ALEXANDRE\Documents\ANIME COPIED MOVIES\Howl's Moving Castle\Menus\1-subs.m2v
    GOP 1, size - 271113
    GOP 2, size - 316737
    GOP 3, size - 96574
    Menu Audio File - None
    Menu Sub-Picture File C:\Temp\259469416_tmpsub1.bmp
    Menu 11 - Type - Motion
    Menu Video File C:\Users\ALEXANDRE\Documents\ANIME COPIED MOVIES\Howl's Moving Castle\Menus\1-chap.m2v
    GOP 1, size - 271175
    GOP 2, size - 317181
    GOP 3, size - 96371
    Menu Sub-Picture File C:\Temp\414512392_tmpsub1.bmp
    * Status Messages *
    Start building Video Title Set ( VTS ) ... - 2001
    Title - 1
    Start building VOB streams - 2210
    Muxing elementary streams is in process ... - 2220
    [INFO] - No audio stream is provided - 3019
    Muxing is in process ... - 2300
    Creating PGC for the title is in process ... - 2500
    Title - 2
    [INFO] - No subtitle stream is provided - 3739
    Verifying Closed Caption file is in process ... - 3750
    Creating dummy menu is in process ... - 2790
    Creating still menu is in process ... - 2700
    Start encoding bitmap ... - 2750
    Reading bitmap is in process ... - 2740
    Initializing audio packets ... - 3005
    Initializing AC3 (MOT) audio packet ... - 3030
    Audio stream is provided - 3017
    Encoding bitmap and building VOBU is in process ... - 2450
    Audio packetizing ends - 3025
    Creating motion menu is in process ... - 2600
    Building VTS IFO stream is in process ... - 2800
    Start building Video Manager (VMG) ... - 2005
    Building VMG IFO stream is in process ... - 2850
    *** Post Verification ***
    No error was found in the post verification process
    Authoring is successfully completed - 3900
    looks like you forgot to put the audio track on the timeline.
    Title - 1
    Title - 2
    Yes, you're right. However, that's just the compilation I did to send you folks the compile log. I had done it before with the audio there on the timeline, and I just did it again. Same result: no audio. I also put the original MKV file on a flashdrive and stuck it in my Blu-ray player. No sound, either. So I'm guessing there may be some problem with the audio that's on the MKV? However, it plays fine on the Media Player Classic in my PC.
    you could try converting from mkv w/ dts to mkv w/ ac3 -
    http://www.videohelp.com/tools/PopCorn-MKV-AudioConverter
    i wouldn't worry about losing the dts, i don't recall anything special about the audio.
    Well, ok, AC3 6.1 would have the same effect. But it's the ONLY audio I have for that file, so if I can't generate the DVD with it, I can't watch the movie (I don't like watching movies on my computer screen, it's a waste of excellent image and great sound, that's why I have a projector, etc.). So, can you tell me of a software I can use to convert the DTS audio to AC3?
  7. Banned
    DTS only audio for a DVD movie is invalid. Some authoring programs will let you do it, but I am wondering if your "player", whatever that is, is enforcing the rules on your DVD.
    By the way, you've been a member long enough to know that cross posting AND grave robbing, which you did in this other thread here on the same subject:
    http://forum.videohelp.com/threads/306915-DTS-sound-from-DVD
    are both not liked in our forums.
    Thank you, I didn't see that on your answer. Sorry about that.
