I would like to copy blu ray disc to hard drive without losing the quality , menus, and sound. Is there any software I can use ?
Please suggest
Best regards,
Mathan
Results 1 to 13 of 13
Thread: Copy Blu ray Disc to Hard Drive
Ok.. I just did a little search .. How about pavtube blu ray ripper?
Is there any video tutorial..... -
Just go to youtube and search for dvdfab blu-ray ripping, like
And DVDFAB and ANyDVDHD are the best. THey are constantly updated. I have no experience with pavtube rippers. -
DVDFab Passkey may also work.
Das Leben ist eine Nebelwand voller Rasierklingen. (C. Bukowski) -
Are .iso files safe? Do they get corrupt over time?
Since they are one big file if anything happens then will recovering the data become impossible?
I am not 100% sure about the iso files getting corrupted?? Can u please tell their safeness it would be a great help. Since i wish to convert the blu-ray folders into iso using imgburn.
I bought AnyDVD because when I looked into AnyDVD and DVDFab, one of the complaints I read about DVDFab was that they nickel and dimed you to death. AnyDVD was much more up front with its pricing. I paid for lifetime updates. I don't have to renew any subscriptions. On the downside, it does seem that DVDFab gets updated sooner and more regularly than AnyDVD. This is not a problem for me, but depending on your taste in movies it might be for you. And AnyDVD sometimes doesn't respond to email so periodically that leads to unfounded rumors that they are going out business or have already gone out of business. Those rumors aren't true, but just last year we had this issue crop up here in our forums.
Thanks for the reply. Downloaded AnyDVD and will try it out this week. Any quick advice on how to rip a BRD to hard drive to stream over my network. I have been doing this for years with DVD Decrypter and DVD's but BR is a whole new learning experience.
Thanks -
I don't do this kind of streaming but maybe it would be helpful to describe your setup and what you intend to play the stream with in order to get the best advice. WDTV players, for example, do not understand BluRay format per se (well, at least the older ones didn't - not sure about current ones) but should be able to play M2TS files.
I don't think you can rip to iso with the free dvdfab decrypter.
Best way to play Blu-ray rips from a hard drive
By idsane in forum Blu-ray RippingReplies: 10Last Post: 12th Apr 2012, 16:46 -
VHS to Hard drive and blu ray?
By david151 in forum CapturingReplies: 14Last Post: 22nd Mar 2012, 10:44 -
Playing my external hard drive from LG blu ray???
By Shadowx22 in forum Newbie / General discussionsReplies: 9Last Post: 17th Oct 2011, 06:21 -
How can we Copy and then Play Blu-Ray´s Discs from our hard drive(Folder)?
By jjulio1 in forum Blu-ray RippingReplies: 4Last Post: 22nd Apr 2010, 12:18 -
wd tv blu ray to hard drive
By bob666black in forum Blu-ray RippingReplies: 7Last Post: 25th Apr 2009, 07:07
