Hi,
Does anyone have experience using the MovieBox 710USB and Virtualdub?
Vdub recognizes the MBox, but I can't capture from a Hi8 camcorder to AVI with out lots of dropped frames and video/audio sync issues. I see lots of recommendations about capturing using the Hufyuv codec, but I don't see it as an option in Vdub.
Using the bundled Pinnacle Studio 15 I can capture to MPEG2, but still have problems with AVI.
VirtualVCR crashes on my system and never starts.
I've tried this with turning everything off using msconfig and disabling my virus scanner (Avira).
My system:
AMD Athlon 64 X2 Dual 3800+, 2.01 Ghz, 3.5 GB RAM,
Capturing to second physical drive. The directory is compressed. Is this a problem?
Thanks,
Chris
Thanks!
Somehow I missed that the codec has to be installed on it's own. Once installed, it shows up in Virtualdub.
Are codecs stand alone windows apps that are called by other apps? I always thought codecs were part of a particular app.
Thanks again,
Chris -
Codecs are still a bit confusing to me but there are codecs(I believe identified with the ending "VFW" - Video For Windows) that do not need to be installed in each individual app that you want to use it in.
Pinnacle usb 500
By kortmann in forum CapturingReplies: 2Last Post: 25th Aug 2010, 23:50 -
Pinnacle Studio MovieBox Ultimate vs. DVD-recorder
By fabitos in forum Newbie / General discussionsReplies: 6Last Post: 24th Nov 2009, 07:04 -
Color Problems with Pinnacle Moviebox Ultimate
By fabitos in forum Newbie / General discussionsReplies: 5Last Post: 8th Aug 2009, 22:37 -
Limited capture success with Pinnacle MovieBox Plus 510-USB device
By ccooper in forum CapturingReplies: 4Last Post: 17th Jul 2009, 11:52 -
Pinnacle Moviebox
By gkoenig in forum CapturingReplies: 0Last Post: 3rd Jul 2007, 12:36
