Hello.
This is my problem.
I have a DK Digital DVD-119 player and so far it served me well. Only problem are subtitles. Won't display them correctly so I decided to hardcode subtitles into .avi files. I downloaded desired movie, then subtitles and I used AVI-Mux GUI to hardcode subtitles. Program did what it was supposed to do and it did it quickly. Then I burned movie to Maxell DVD+RW using CDBurnerXP. That also went as planned. Now it gets little strange. I inserted DVD+RW into DVD player, selected movie and after only 17 seconds DVD player stopped movie and switched to menu. I tried again but to no avail. I erased DVD+RW and this time burned movie at lower speed. Again the same problem. I erased DVD+RW again and this time I burned original version of movie with no subtitles hardcoded and it worked just fine. Later while examining movie files I discovered that Data Rate and Total Bitrate are diferent (picture below). Could this be the problem and if it is how do I fix it?
P.S.: Image on the right is the unchanged video and image on the left is video with hardcoded subtitles. You can see that the original is has much higher Data Rate and Total Bitrate than the hardcoded one.
I'd guess you added the subtitles to the AVI as a subtitle stream, but unless AVI-Mux GUI has encoding abilitites I'm not aware of, you wouldn't have hardcoded the subtitles using it.
Maybe try MediaInfo to get the details of each AVI and post them here. I'm not sure I'd trust Windows to provide anything accurate. The AVIs would have to be dramatically different in size to have such different bitrates. -
Avimuxgui doesn't hardcode subs. Try instead autogk (click on it for guides).
Or try mux the subtitles to the avi with aviaddxsubs.
And I changed your thread title. -
Thank you Baldrick. I used both AutoGK and AVIAddSubs. AVIAddSubs didn't work the way I expected. When I played DVD in DVD player it gave me a lightshow and it skipped time. AutoGK on the other hand did what I wanted all along. Output file was bigger than input (input was 800mb, output was 1.16Gb), but that was acceptable.
Thank you again.
This thread can now be closed -
HA HA HA HA HA HA HA HA HA HA HA...
You really have no idea how things work around here.
If only it were that simple. Your thread may stay open forever with the very real chance that some future new forum member will dig it up perhaps as late as 8 years from now and needlessly add to it. The only threads that ever get closed are those that advocate a violation of the forum rules (actually, your first post did that when you admitted to downloading the movie and this thread may eventually be closed for that reason) or degenerate into name calling and no longer serve any purpose other than for 2 or 3 people to verbally fight with each other. -
extract subs from MKV -- MKVextract doesn't work
By AlanHK in forum Video ConversionReplies: 4Last Post: 9th Dec 2011, 22:47 -
AVI on DVD/DivX- player, weird problem
By baranjac123 in forum Newbie / General discussionsReplies: 19Last Post: 23rd Mar 2011, 10:55 -
Please help! New DVD player doesn't work :(
By confuzedinTN in forum DVD & Blu-ray PlayersReplies: 3Last Post: 20th Sep 2010, 13:44 -
Subs work on PC/VLC Player...but don't show up on dvd player
By bgart13 in forum SubtitleReplies: 9Last Post: 22nd Aug 2009, 18:06 -
Playback Error on DVD player..... Process used to work now it doesn't!
By Sisi in forum Authoring (DVD)Replies: 3Last Post: 23rd Feb 2009, 13:07
