I never bothered much with the structure and syntax of scrips inasmuch as I was content to use samples from posts etc, but trying to make sense of them, I wanted to clear-up a point.
What does the 'clip' refer to in these examples - and why does it sometimes refer to clip2?
AssumeFPS [yv12] [yuy2] [rgb32] [rgb24]
AssumeFPS (clip, int numerator , int denominator, bool "sync_audio")
AssumeFPS (clip, float fps, bool "sync_audio")
AssumeFPS (clip1, clip2, bool "sync_audio") [v2.55]
AssumeFPS (clip, string preset) [v2.57]
If you don't specify a "clip" (A/V stream) AviSynth will use the "last" A/V stream. For example:
implies:Code:AviSource("filename.avi") AssumeFPS(60)
and that is the same as:Code:last=AviSource("filename.avi") last=AssumeFPS(last, 60)
Pretty much all functions require a "clip" to operate on. Some functions require (or accept) more than one clip:Code:AviSource("filename.avi") AssumeFPS(last, 60)
Code:vid1=AviSource("filename1.avi") vid2=AviSource("filename2.avi") last=Merge(vid1, vid2)Last edited by jagabo; 23rd Mar 2012 at 17:19.
X264 CLI Syntax Help
By Eva-Unit01 in forum DVD RippingReplies: 9Last Post: 2nd Dec 2011, 17:42 -
FFMPEG 2-pass syntax help needed
By ITemplate in forum Video ConversionReplies: 7Last Post: 2nd Jul 2011, 19:41 -
Useful FFmpeg Syntax Examples
By Soopafresh in forum Video ConversionReplies: 23Last Post: 16th Aug 2010, 16:15 -
Syntax error
By zecamigo in forum ffmpegX general discussionReplies: 4Last Post: 12th Mar 2009, 11:16 -
Syntax bug in SVCD2DVD
By geek2330 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 27th Nov 2007, 11:14
