I have installed the Bigasoft Total Video Converter and I'm trying to convert a mkv file with DTS audio to a mkv file with AC3 audio but the convertion also affects the quality of the video.What can I do?
Results 1 to 14 of 14
Thread: Dts to ac3
I have a feeling not many members here know anything about that software. But maybe someone will prove me wrong. Is there no way with that software to simply copy the video stream and re-encode the audio?
OTOH, RipBot is well-regarded here and can easily do the job. Select the input, let RipBot analyse and demux the file. Set container to MKV, video to copy stream, and audio to AC3, 5.1 at 448 or 640 kbs. Guides are available.
Good luck and welcome to the forum.Pull! Bang! Darn! -
Popcorn MKV AudioConverter can convert MKV DTS to MKV AC3. I think eac3to can also do the conversion but you may have to demux the audio file first.
I downloaded the Popcorn MKV Converter but all the bars are red. What can I do?
Never tried Popcorn MKV Converter.
Have used MKV2AC3 in conjunction with eac3to. It works for me. -
There are many tools that let you just copy the video while encoding the audio. Another one is AviDemux.
http://www.FavesSoft.com
"I don't want to belong to any club that would have me as a member."
- Groucho Marx -
And which ones are they (on a mac
- Groucho Marx -
malkekoen - Don't hijack threads. The original thread was not Mac specific. Your question is. ANYTHING that is Mac specific needs to go in our Mac forum or you likely won't get help. Next time just make a new thread in the Mac forum for a question like this. And don't dig up old threads to post to them unless what you have to say is absolutely critical information that nobody has stated previously. Asking a question does not fit this idea of being "absolutely critical information". Generally speaking just leave old threads alone and open a new one around here if you need to know something.
Hi
With Windows and Linux versions of VLC it's simple to set up new profiles in "Convert/Save" wizard.
Encapsulation - MKV
Video codec - Keep original video track
Audio codec - A52/AC3
This probably applies to the Mac version of VLC too.
Simplet method if you do not want to touch video at all is use MKVEXTRACTGUI2 to extract dts audio file
Convert it to mp3 or ac3 using any tool for example freemakevideo maker
remux the audio with again using mkvmerge GUI
DTS to AC3 5.1
By daemon22 in forum AudioReplies: 78Last Post: 24th Sep 2011, 09:04 -
AC3 5.1 to DTS 5.1
By Benjy in forum AudioReplies: 3Last Post: 18th May 2010, 06:27 -
DTS to ac3
By Han Solo1 in forum Newbie / General discussionsReplies: 1Last Post: 29th Apr 2010, 12:24 -
Reauther dvd with pcm & dts to ac3 & dts
By djblade in forum Authoring (DVD)Replies: 9Last Post: 16th Feb 2010, 08:40 -
AC3 to DTS
By Tolis1989 in forum AudioReplies: 2Last Post: 15th Nov 2008, 12:12
