Hi,
Is it possible to remove a single channel from a 5.1 ac3 file? I have a file I would like to remove 1 track (probably centre track) from the file. Im not worried about the output being 5.1 or 2Ch or whatever, long as it is not Mono I don't really mind to much
Im sure someone told me it could be done with Canopus Procoder, but I have not found the option.
Any tools that can be suggested would be great, also maybe a brief guide on what to do, in case I get stuck, hope thats' not to much trouble.
Thankyou in advance![]()
Results 1 to 10 of 10
i gave besweet a try but couldn't find the 6wave option mentioned. i will have a go with audacity when i get home and see if i have any luck i did already try importing the file into audacity earlier but it didn't work but that was without the addon mentioned so hopefully that will be the case
thanks for taking the time to reply. -
I know just a warning really. jonhso, I don't want to hijack the thread but can you answer me question while you're here?
If I import 5.1 from an original source I get 10 minutes of silence added to the beginning of the track. Do you have any idea why that is? -
The only time i had problem with ac3 files is that they were improperly encoded,when you load the file do you see 10 minutes of silence?If you do just delete that part.
Yes I do. Exactly 10 minutes from an original .vob file. What you said sounds about right...it was the end titles only...wanted the soundtrack from the end credits. Forgot about that. Split .vob maybe. And yes did a silence scan and cut at the flags. All sorted. Thanks for the reply.
Splitting 2 channel AC3 Audio
By jaesun in forum Newbie / General discussionsReplies: 7Last Post: 14th Apr 2012, 15:41 -
movie with two ac3 2-channel audio tracks one is mono, which one?
By pm1315 in forum Authoring (DVD)Replies: 1Last Post: 25th Oct 2011, 13:14 -
AC3 File: Audio only on left channel
By koberulz in forum AudioReplies: 10Last Post: 25th May 2011, 12:07 -
How to Author AC3 5.1 Channel Audio Only DVD Using DVDLab Pro 2
By Hittz in forum User guidesReplies: 10Last Post: 3rd Apr 2011, 00:05 -
Convert stereo ac3 with bad channel to mono ac3
By chipsndukes in forum AudioReplies: 7Last Post: 5th Nov 2008, 11:23
