  1. Member jollyjohn's Avatar
    G'day all
    Could anyone please tell me if a MB GA-8S648FX-775(-C) would take a E6600 processor. It would match the 755 pins but, would it run well? The MG can support ram:
    Memory ? 3 DDR DIMM memory slots (supports up to 3GB memory)
    Supports DDR400/DDR333/DDR266 DIMM
    Supports up to 2 unbuffered DIMM DDR400
    Supports up to 3 unbuffered DIMM DDR333
    Supports only 2.5V DDR DIMM
    Enough to run W732
    Currently runs:
    Type : Intel Pentium 4
    Internal Specification : Intel(R) Pentium(R) 4 CPU 3.20GHz
    A0 : Empty
    A1 (RAS 3, RAS 4) : 1024 (Double Bank)
    ÃËh (RAS 0, RAS 9) : 512 (Double Bank)
    Thanks for any replies.
    John
    That motherboard is not compatible with an E6600 CPU according to http://www.gigabyte.com/support-downloads/cpu-support-popup.aspx?pid=1890
  3. Member jollyjohn's Avatar
    Thanks, usually_quiet
    I'll keep it as it is for a while. I can always use the shell to put something bigger in it in the future if I needed to. I have a dual core 64bit system with 8GB Ram to do the heavy stuff and that is enough for me at the moment.
    I rarely do any Cad Cam Programming now, I'm a 70 year old bugger, but I still enjoy a little or big brain challenge from time to time.
    Thanks, mate
    John
