I am working on a dvd-audio disc, but need to know the best software to use to create a menu - Free software is always good I made the dvd-audio w/ Lplex and I have chapters .. but I need to add a menu to navigate easier .. any suggestions ? Thanks !
Far-out ! Thanks for this and the quick reply .. I'm going to give it a shot .. Thank you again !
What's up w/ gui for dvdauthor .. can't seem to get it to take the files .. menu looks bangin' .. but can't load material into it . I have WAVE's to load into it or the DVD Image file made from them .. instructions in the manual doesn't seem to be user friendly to say the least .. Thanks in advance, TYD
I haven't used it in years...
Maybe in doesn't support your wav files.
I guess you are making a standard dvd-video with audio? ANd not any real dvd-audio, http://en.wikipedia.org/wiki/DVD-Audio -
Nope ... not video at all .. it's DVD-Audio .. and it says that it supports 24/48 WAVE's but .. it just doesn't seem to tell you how to load them .. I usually do 24/96 recordings .. but this time it was 24/48 .. of The Fixx .. from 2010-7-31 Busch Gardens, Va. .. when I went there that year ... I have made dvd-audio before .. but not w/ a menu .. just a dark screen .. The sound quality is much better than your standard CD quality 16/44.1 .
Actually, the 'Chapter Playlist' won't light up .. it's functionality is dead .. if it weren't for that I could load the files ..
Doesn't matter, both those apps ONLY do DVD-VIDEO.
You'll need DVD-Audio Tools, Cirlinka, Discwelder, or a Scenarist version that supports DVD-Audio.
The 1st is opensource and does support a main menu.
DVD with chapters already I only want to make a menu while retaining all...
By dbbarney in forum Authoring (DVD)Replies: 6Last Post: 4th Oct 2010, 12:05 -
Make menu for a movie dvd that have subtitle and have not any Menu!
By p_samimi in forum Authoring (DVD)Replies: 1Last Post: 13th Feb 2009, 14:29 -
How do I make a menu for a video_ts folder that has no menu?
By ericg42 in forum Authoring (DVD)Replies: 5Last Post: 9th Jan 2009, 06:02 -
Software to make sure the audio and video of a authored dvd are in sync?
By snafubaby in forum Authoring (DVD)Replies: 7Last Post: 1st Oct 2007, 07:13 -
how to make a dvd from 2 or more different dvds with menu and subs??
By vinayak1986 in forum Authoring (DVD)Replies: 1Last Post: 9th Sep 2007, 01:59
