Results 1 to 9 of 9
  1. Hi, I have QuickTime, and with the help an MPEG2 plugin, i can play DVDs, but there's NO sound. I'm wondering if QuickTime can somehow play DVD audio (i believe it is AC-3 format) in Windows?
    Thanks in advance
  2. Just installed AC3Filter, but it does NOT work with QuickTime, i still get NO sound from DVD, even restarted,too. Any other codecs or suggestions would be great.
  3. If you are using Windows...does the DVD play in Media Player? Why, may I ask, do you need to use QuickTime in preference to VLC portable or MPC?
  4. Just use VLC player and forget about Quicktime player.
  5. Member Cornucopia's Avatar
    There is an "A52" codec (aka AC3) for Mac (which I believe is bundled with Perian) that plugs into Quicktime for Mac, but there is NO SUCH codec within the Quicktime platform on Windows. Best to either use VLC (or similarly self-contained player) or rewrap from QT -> AVI and use standard Directshow AC3 plugins (like the AC3 filter mentioned above).
  6. Well, VLC plays choppy video, especially QuickTime format, on every PC i have used. What is meant by "rewrap QT--> AVI"? Isn't AVI a video codec?
  7. DECEASED
    Jun 2009
    Heaven
    AVI is a container, not a codec.
    On Windows, MPC-HC + LAV Splitter + ffdshow is all you need for playing MOV / QT / MP4 files.
    Both VLC and QuickTime suck too much, just don't use them, case solved.
  8. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    VLC plays anything....and very well on my PC.
