I now have software that will edit and author in 60P. However, my Blu-Ray player cannot play it. It plays only on the computer Is there a player that can play to AVCHD 2.0 and if so, what is it? Blu-Ray player is an LG BD-550. I will check for firmware update but, I doubt it exists for this mode.
one solution is to go away from optical media storage , away from their copyright politics , check out those- find one that plays 60p:
http://www.iboum.com/net-media-players.php
yes, you can have both, BD player and one of those little boxes that can play anything fom HDD, thumbdrive, over LAN also. And you will still be better off. -
There is a Version 2.0 spec for AVCHD and a separate Version 2.0 spec for future Blu-Ray players that adds 1080 50p/60p, 25p/30p AVCHD Lite and compatible 3D playback modes.
Sony and Panasonic control the AVCHD spec. LG is part of the Blu-Ray Association.
Each company will announce new Version 2.0 players. Sony has stated that some current players will be updated with a firmware update but hasn't identified which models can be updated to Version 2.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Can i burn avi/mp4/mkv etc to blu ray media and play it in a blu ray player
By brad350 in forum Newbie / General discussionsReplies: 10Last Post: 21st Apr 2012, 04:15 -
can you make a blu ray that is is 60p?
By Onceler2 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 23Last Post: 12th Jan 2011, 01:38 -
Blue Ray 60P?
By wulf109 in forum Blu-ray RippingReplies: 1Last Post: 6th Jan 2011, 02:21 -
Blu-ray discs created in 1280x720 60p
By Persistence in forum Authoring (Blu-ray)Replies: 6Last Post: 2nd Jun 2009, 17:05 -
Can I rip Blu Ray Discs with LG Super Multi Blu-ray Disc and HD DVD-ROM Dri
By donpato in forum Blu-ray RippingReplies: 5Last Post: 5th May 2008, 16:05
