I have had this dvd player for approx 15 months and it has been unlocked for all that time.
All of a sudden whilst i was watching the AVI file movies it stopped playing them.
None of the DVD's that have worked on it are working anymore.
it loads and the menu shows. Then i select the movie and the Index goes to a 100. Then the screen goes black and display shows 00:00 as though the movie is starting but it is stuck there. I have tried countless DVD's that worked previously.
What has happened? Please help.
Sounds like your dvd player has gone kaput and needs to be replaced,it's not worth repairing since they are so cheap now a days.
This link might give you some ideas. Not exactly the same problem you face, but some of the no-cost/low-cost fixes might work.
https://forum.videohelp.com/threads/325359-drawer-won-t-shut-on-Medion-DVD-player -
So you're saying store bought pressed dvd's play ?
I had a player do that a couple of years ago.
I can't remember which way it was, it wold not play burnt media but would pressed media, or vice versa.
I took it apart and carefully cleaned the laser lens and then it worked perfectly again.
If nothing else has changed, no firmware updates, it's either a dirty lens or the laser is dying.
Either way, it won't hurt to try.
A few days ago one of my Bluray players stopped reading DVD's, both burnt and pressed, just said "no disc"
but it would play Bluray's, pressed and burnt.
Cleaned the lens on that one also, started working perfectly again.
MKV files suddenly not playing properly on VLC
By thekenoshakid in forum Newbie / General discussionsReplies: 5Last Post: 6th Dec 2011, 00:24 -
My phillips dvp3980 Stops playing movies 3/4 of the way through.
By UmmAddan in forum Newbie / General discussionsReplies: 10Last Post: 22nd Nov 2010, 16:36 -
Power2go suddenly stopped working properly
By DaneClark in forum Authoring (DVD)Replies: 0Last Post: 7th May 2010, 18:06 -
Windows Media Player stopped playing .mov files
By dzsoul in forum Software PlayingReplies: 2Last Post: 19th Mar 2009, 00:29 -
EZ Takes DVD suddenly stopped working?
By greenr18 in forum Software PlayingReplies: 1Last Post: 13th Nov 2007, 13:17
