hello, i recently bought SONY DVP-SR750H . I have one problem with it. it can only play some avi files . whenever i want to play a movie i get ; data error (video) . i've read on other site, that someone had the same problem but with another sony dvd player and he fixed it by downloading latest firmware. unfortunately there is no newer firmware version on the internet for my dvd player .
what do you guys think. thx in advance.
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
Closed Thread
Install MediaInfo and post what it says about your problem file. It could be that there is something wrong with it that you can't see.
If the file looks like it is OK, it could possibly one of the following:
You're trying to play from a USB device and not telling us.
The ones that work are on a media brand that is different from the ones that don't work.
The discs that don't work are burned in UDF format and the ones that work are burned in ISO/JOLIET format.
Something else.
here is the description from mediainfo .
p.s. it doesent matter if i use usb or dvd disc it doesent work either way .
General
Complete name : H:\Filmy\Star.Wars.I-VI.Collection.DvDrip-aXXo\II-Attack.Of.The.Clones[2002]DvDrip-aXXo.avi
Format : AVI
File size : 789 MiB
Duration : 2h 16mn
Overall bit rate : 807 Kbps
Writing application : VirtualDubMod 1.5.10.1 (build 2366/release)
Writing library : VirtualDubMod build 2366/release
Video
Format : MPEG-4 Visual
Format profile : Advanced Simple@L5
Format settings, BVOP : 2
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Codec ID : DX50
Codec ID/Hint : DivX 5
Duration : 2h 16mn
Bit rate : 702 Kbps
Width : 660 pixels
Height : 272 pixels
Display aspect ratio : 2.40:1
Frame rate : 25.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.156
Stream size : 686 MiB (87%)
Writing library : XviD 1.0.3 (UTC 2004-12-20)
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Codec ID : 55
Codec ID/Hint : MP3
Duration : 2h 16mn
Bit rate mode : Constant
Bit rate : 96.0 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Stream size : 93.9 MiB (12%)
Alignment : Aligned on interleaves
Interleave, duration : 40 ms (1.00 video frame)
Interleave, preload duration : 504 ms
DVD9 cannot play on SONY DVP-NS55P
By techworld in forum DVD & Blu-ray PlayersReplies: 15Last Post: 1st Aug 2018, 21:45 -
Sony DVP-NC665P - Cannot Play DVD's Consecutively Automatically
By searchlight in forum DVD & Blu-ray PlayersReplies: 1Last Post: 12th Feb 2011, 00:21 -
SONY DVP-SR700H - squashed DivX picture
By jhrebacka in forum DVD & Blu-ray PlayersReplies: 2Last Post: 9th Nov 2010, 10:21 -
Can't play MP3s on my Sony DVP NS355 DVD player
By harrylentil in forum DVD & Blu-ray PlayersReplies: 4Last Post: 6th Aug 2009, 14:04 -
Can I play HD divx files on a NON-BlueRay Player (DVP-5990)?
By DVantrease in forum DVD & Blu-ray PlayersReplies: 17Last Post: 20th Nov 2008, 15:18
