Results 1 to 11 of 11
    Feb 2012
    Cyprus
    Hello,
    My DVB-S2 records video files in TS format (there's another option, but I don't rememeber what it is).
    I uploaded a 1 minute recording in normal and HD formats to the following links:
    http://www.mediafire.com/?7iyita2yntx7l6o
    http://www.mediafire.com/?ugtscwkka40rfa5
    I would like to be able to convert recorded videos to MKV or AVI/MPG files.
    It is possible? If yes, how?
    Thank you in advance for your attention.
    Can you play those files in any player like VLC?
    The first clip is just garbage in vlc and avidemux. Downloading the other now...mediafire is sloooooow.
    Feb 2012
    Cyprus
    No. I tried to change the file extension, but couldn't play it with anything
    It's significantly larger, as it's HD
    The dvb recorder probably uses some special/encrypted video format....so you can't do much.
    Feb 2012
    Cyprus
    I'll try in the other format, but if it is indeed the case (somehow, I find it strange to believe that they would bother) and upload a demo file too
    Thanks for your help
  6. Would be good if you wrote what tuner you have... Anyway, you need this tool from Ferguson (TS Tool): http://www.ferguson-digital.eu/en/download/func-showdown/680/
    It converts dvr (info.dvr file needs to be in the same folder) into standard transport stream (*.ts) container.
    Good luck.
    Feb 2012
    Cyprus
    It's called S-CLASS HD8899. Terrible thing. Very unstable (forget about proper support, too!!!) and really not recommended, but for now, it's all I have.
    I managed to convert the file to ts with that app. THANK YOU, THANK YOU, THANK YOU!!!!!!
    That's exactly what I needed.
    Now, how can I convert the ts file to mkv?
    Thanks again
  8. I'm a MEGA Super Moderator Baldrick's Avatar
    Nice.
    If you want to shrink the ts to a smaller mkv could you try latest handbrake. Just released.
  9. To convert .ts to mkv, you can also use GDSMux which is installed with Haali Matroska Splitter: right click and from a pop up menu choose add source. After then write name of the output file.
    Feb 2012
    Cyprus
    With handbrake, 1m20s clip (the 2nd one above) took more than 13 minutes to convert, but the size dropped from more than 100M to 75M.
    It took me only around 7 secs to convert using GDmux, but the size remained practically the same: 98M. Still, spending 10 times the duration of the clip with handbrake is not practical.
    Thanks everyone for your support. I got everything I needed from your different answers
  11. I'm a MEGA Super Moderator Baldrick's Avatar
    Yep. Reconverting(so you can SHRINK it ) HD takes some time.
    You could also use mkvtoolnix / mkvmergegui and add the ts and make a new mkv. No reconversion. Mkvmergegui and gdsmux are just "remultiplexing" to mkv so it should always be fast.
