Hi Guys
I haven't had to do this in a long time and I forget ...
I have a source that is a 29.970fps progressive AVI
When converting to NTSC DVD do I enable 3:2 pulldown or not?
I'm using HCenc for the video.
I feel like such a newbie asking this LOL
- John "FulciLives" Coleman
Hi Fulci!
If it's true progressive 29.97fps (every frame is unique - no dupe or interlaced frames), then no 3:2 pulldown. The resulting 29.97fps M2V/MPV will be DVD compliant already. -
Thanks manono
I just ended up encoding it at 29.970fps (without pulldown which I realized after posting this that HCenc wouldn't let me select pulldown anyway).
The resulting DVD plays as does the original AVI. It's not smooth but the original is not either. It (the NTSC DVD encoded video) looks the same as the AVI motion wise.
I looked at the AVI in VirtualDub just now and it seems to be have a pattern of ... well I dunno what you would call it. Every two frames are identical. So frame 1 and 2 are the same, then frame 3 & 4 are the same, then frame 5 and 6 are the same etc.
This was recorded from some "YOU TUBE" like website. A chinese site no less (the film is a rare Shaw Brothers film that has never had a DVD or better release).
Is there anything I can do to make it better?
P.S.
All I have is this AVI file. There is nothing better that I could find."The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
if every frame pair in the AVI is a duplicate, then the fps of the AVI is actually 15. So if you used selecteven() or selectodd() to drop the duplicates, this would give you 15 fps (unique frames)
you can try to generate synthetic "inbetween" frames with mvtools2, but you probably won't get good results on an action movie like shaw brothers kung fu flick (there will be weird edge morphing artifacts)
you can try mflowfps, or interframe for example
http://forum.doom9.org/showthread.php?t=160226 -
I tried playing around with interframe but it seems to want to make it 60fps even if I do a selecteven() first with decomb
Unless my scripting is wrong. Sigh."The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
I randomly chose SelectEven(), but you can just choose SelectOdd() if you want
Code:AVISource("video.avi") SelectEven() source=last super = source.MSuper(pel=2) backward_vec = MAnalyse(super, overlap=4, isb = true, search=3) forward_vec = MAnalyse(super, overlap=4, isb = false, search=3) source.MFlowFps(super, backward_vec, forward_vec, blend=false, num=30000, den=1001)
Are you certain the pattern holds throughout the entire video ? duplicate frames ?
Progressive AVI encoding to DVD in TMPEnc - interlaced?
By Xoanon in forum Authoring (DVD)Replies: 16Last Post: 9th Jan 2009, 11:01 -
Encoding progressive NTSC material with Canopus Procoder 1.5?
By zee944 in forum Video ConversionReplies: 8Last Post: 13th Oct 2008, 07:56 -
3:2 progressive scan pulldown support.
By wasimismail in forum Authoring (DVD)Replies: 47Last Post: 11th Jun 2008, 21:51 -
TMPGEnc: 720P -> Progressive or 3:2 Pulldown?
By akrako1 in forum Video ConversionReplies: 6Last Post: 13th May 2008, 12:51 -
NTSC-PAL-NTSC (25-23.976+pulldown) and audio sync problem - related?
By ecc in forum Video ConversionReplies: 14Last Post: 14th Nov 2007, 11:34
