How to rip and convert a Blu-ray main movie to a standard DVD using free software. You will lose the blu-ray menu and extra material but you can keep several audio tracks and subtitles.
Tools
DVDFab HD Decrypter
BDRebuilder (requires ffdshow, avisynth and haali media splitter installed)
Imgburn
Ripping
Rip your Blu-ray to your HDD using DVD HD Decrypter.
Start DVDFAB HD Decrypter and select HD Decrypter Free Edition.
Select the blu-ray drive and set the target. You need a lot of HDD Space, 20-50GB!
Conversion
Be sure to install the required tools for BDRebuilder first, ffdshow, avisynth and haali media splitter.
Extract all files from bdrebuilder.zip to a folder and run inspect.exe and click inspect, it should say OK on all line if you have installed all the required tools.
Now start BDRB.exe
Select the source folder where you ripped the Blu-ray using DVDFab HD Decrypter.
Select the working folder. Be sure that you have enough HDD Space, around 15-30GB!
Select Mode->Movie Only Backup
Select the audio and subtitle tracks you want to keep. Double click to disable/enable track. Try to avoid to include so many audio and subtitle tracks, they take some space.
Select Mode->Movie Only->Alternate Movie Only Playlist and select DVD-5(4.7GB DVDRs) or DVD-9(8.6GB DVDRs)
Backup!
You can now test play the DVD with VLC Media Player, in VLC choose Media->Open folder and select the VIDEO_TS folder that BDRebuilder created.
Burning
Burn the VIDEO_FOLDER with Imgburn
Select Write Folders/Files to DVD.
Add the VIDEO_TS and AUDIO_TS folder.
Burn
Problems
If everything fails then just buy the full version of DVDFab and you can do Blu-ray to DVD directly in it.
I've used BD Rebuilder for this process a number of times now. It usually works very well, and the HC encoder does a fine job from blu ray sources. Problems sometimes occur when the original audio is DTS-HD Master Audio, and that is becoming a very common type of audio in blu ray.
As to using DVDFab to do the complete conversion from blu ray to dvd...I wouldn't advise it. I tried it not long ago while I had the full trial for DVDFab and whatever they are using for mpeg2 encoding is simply not producing very good results. -
All 3 of my "WIN7 preferred" codecs are "Not Set correctly" but the 3 installed tools show ok.
How do I correct this? -
How to easily convert a Blu-ray to MP4/M4V/MKV using free tools
By Baldrick in forum User guidesReplies: 16Last Post: 30th Jan 2013, 12:30 -
How to convert Blu-ray to standard DVD-Video (or MKV,MP4) using free tools
By Baldrick in forum User guidesReplies: 2Last Post: 27th May 2011, 16:06 -
Any way easy to convert blu-ray and hd-dvd to standard def dvds?
By tecnition_teds in forum Blu-ray RippingReplies: 40Last Post: 6th Mar 2011, 20:39 -
DVDFAB Blu ray to blu ray free version stopped working
By kohlirowe in forum Blu-ray RippingReplies: 3Last Post: 5th Jul 2010, 10:50 -
Suggestions/tools to rip/convert from Blu-Ray to MP4 for iPAD ?
By SMaldo in forum Blu-ray RippingReplies: 3Last Post: 20th Apr 2010, 11:21
