Please
Can you tell me the best way to convert a a BluRay Movie to MKV ( with size DVD9 oe else)
What about with Blu-ray Converter Ultimate ( http://www.vso-software.fr )
thanks
Results 1 to 10 of 10
DvdFabHDdecrypter with Vidcoder or Ripbot will do the trick..for free
As stated by others rip with DVDFadHDDecypter and convert to mkv with handbrake\vidcoder or ripbot264.
Of the three vidcoder is the easiest to use, but it still requires you to install handbrake as it is a simplified user interface for Handbrake.
Using Handbrake it self will open up a few more encoding options for you.
Ripbot will allow you to fully tweak your settings for better overall results, (i.e. x264 encoder settings via customizable profiles, audio encoding, and avs scripts.Murphy's law taught me everything I know. -
Vidcoder uses Handbrakes engine (you don't need to have the latter installed). The advantage being that it contains a more robust and fuller featured GUI interface compared to the Window's version of Handbrake (whose GUI features favor the Mac build).
There's no quality tweaking involved, nor is Handbrake merely a click and convert app.Last edited by Meritocracy; 12th Feb 2012 at 19:55.
What exactly is rotten in Denmark? -
I tried VSO Blu-Ray Converter Ultimate after using VSO Convertxtodvd for years, And it is an excellent program, After all the reviews with BDrebuilder I decided to try that about 4 weeks ago, But I have to many problems with it, One time it works and next time it always comes up x264.exe has stopped working.
How to convert a BluRay disc into a .MKV 720P file
By ioannis66 in forum User guidesReplies: 25Last Post: 1st Jun 2013, 04:19 -
Convert MKV DVD9 to MKV DVD5
By CR88 in forum Video ConversionReplies: 1Last Post: 23rd Aug 2011, 07:55 -
Easy Question.. Convert mkv to DVD9
By WareISChris36 in forum Blu-ray RippingReplies: 1Last Post: 21st Jul 2011, 15:22 -
Convert BluRay to MKV with MKVmerge no FPS set
By whachano in forum Blu-ray RippingReplies: 0Last Post: 23rd Feb 2011, 16:16 -
Using tsmuxer to convert mkv to bluray and the aspect is squished.
By heckybaby in forum Authoring (Blu-ray)Replies: 8Last Post: 9th Jun 2010, 08:07
