VideoHelp.com Forum
Results 1 to 10 of 10
  1. Hi All,
    Is there any way to sent TMPEGEnc project file to AVIsynth and it'll play in Windows Media Player?
    ketdael
    Convert the project with VFAPI and load it in Avisynth with AVISource.
    I can not see a reason why one would do that, but it is possible.
  3. We have file called rtv.vfp. Now we can load uncompressed RTV files fro NLE editor directly to TMPGEnc. File works fine in TMPGEnc, AviUtl but does not work in DVD2AVI apps. If i convert it to AVISource CCE does not work that fast like with DVD2AVI projects. I'm not good in creating of AVISynth scripts just trying
    ketdael
    You may also try to load the VFAPI plugin into Avisynth. The script should look like this:
    LoadVFAPIPlugin("c:\..fullpath...\rtv.vfp","AVISource")
    AVISource("d:\..fullpath..\filename.avi")
    However, VFAPI work with RGB colourspace only, so at least one colourspace conversion is necessary, that slows the whole process down of course.
  5. Does it look right?
    LoadVFAPIPlugin("D:\TMPGE\rtv.vfp","AVISource")
    AVISource("G:\Test_tpr-vfapi.avi")
    If you convert the TMPG project with VFAPI just type
    I assume the path is correct. Always preview an .avs with windows media player. If anything is wrong with the script, it will give you a quite exact error message.
    I think you can load the rtv file (whatever rtv means, I have no clue) directly into Avisynth.
    AVISource("G:\Test.avi")
    Since it is even possible to load .vob files with the m2v.vfp plugin and AVISource, I believe that should work. I can not proof it.
    Play the 2nd .avs above with Win media player, it may be displayed upside down. Then you have to add a FlipVertical line, so the script looks like this:
    FlipVertical
  7. It Looks like this
    LoadVFAPIPlugin("D:\TMPGE\rtv.vfp","Test.tpr")
    Still slow, is there any way to do it without avisource only use .tpr or convert it to .dvd2avi or anything else :-)
    If I ever knew what "rtv" is... Is it an avi codec? Can you play that files with windows media player?
    Did you ever try to load the rtv file directly?
    AVISource("c:\..path..\rtv.avi")
    or
    DirectShowSource("c:\..path..\rtv.avi")
    #does not support audio
  9. Here is some info:
    To use, please place the file "rtv.vfp" in the same directory
    as "TMPGEnc.exe" installed, and then run TMPGEnc. You will
    now be able to load RTV files within TMPGEnc the same way you
    can AVIs (i.e. from the main window and from the wizards).
    Whats New?
    This version converts 486 line RTV video to 480 lines. This
    means no more manual cropping to obtain clean video! A VERY
    big thank you to Pat for help on this. As a side benefit of
    this change, there is no longer the need to set 'B' field
    order.
    A note on usage:
    When you load a RTV with embedded audio, TMPGEnc will
    automatically set the audio filename to the name of the RTV
    (duplicating the name of the Video filename). You can override
    this with another audio filename by then selecting another audio
    source, such as a wave file. A RTV with no audio will blank the
    audio filename.
    If their are any problems, suggestions, or comments, please
    feel free to e-mail me at either kmorger@azstarnet.com or
    kirkmorger@tcisolutions.com if it is between the hours of
    8-5MST monday thru friday.
    Thank you to www.toastersupport.com for hosting this plug-in!
    RTV is uncompressed video file for NewTek VideoToaster NLE
  10. There is only one problem can't use it in CCE have to convert to avi from TMPGen.tpr with VFAPI CoDec and it slows CCE.
  1. Can I edit HiDef files in same project as StandardDef files?
    By cspaul1234 in forum Newbie / General discussions
    Last Post: 10th Jul 2011, 19:39
  2. Studio14 HD Ultimate, can't open project files from ext. HDD!!!
    By rivrbyte in forum Newbie / General discussions
    Last Post: 9th Jul 2011, 14:49
  3. Replies: 5
    Last Post: 21st May 2011, 18:25
  4. Project HD Image files without jaggies
    By tram in forum Newbie / General discussions
    Last Post: 15th Jun 2009, 12:37
  5. Updating files inside a project
    By paulom in forum VCDEasy General
    Last Post: 23rd Sep 2008, 14:00
