  1. I want to encode a group of low-quality MPEG-4 video files to DVD format (to eventually burn to a DVD).
    The problem is that when I encode the video, the resulting files are often 2-3x as large as the original video files.
    How can I encode the video files so that they are in DVD format, roughly the same quality, and roughly the same file size as the originals?
    File size = bitrate * running time
    Use a lower bitrate. But the results will probably look very bad since MPEG 2 encoding requires more bitrate to retain quality. You can ameliorate the problem by using a smaller frame size, 352x480 or 352x240 for NTSC, 352x576 or 352x288 for PAL.
    The better solution is to get a player that can play your MP4 files.
    http://www.iboum.com/net-media-players.php
