hello
i have a pair of in-ear earphones that when I dont play any sound in my pc, there is a constant buzz heard
when i play sounds in my pc, that buzz gets covered
what can I do to fix it?
I cannot say if it is pc problem or earphones problem, because I have no other earphones to test in my pc
any idea?
thanks!
Try the earphones on another device -- like a TV. But it's almost certainly a PC problem. Do you have onboard audio? That's usually not so good.
try different headphones.
It's interference from all the electronics within the PC. Depends a lot on the sound card you have but these days mostly on-board and they are not well shielded. You need to try them on another device like a noise making TV - if it is clear then the problem most likely is the shielding within the PC and there's not much you can do about it. A better external sound card like an E-MU or Creative SoundBlasterX-Fi would be best if you are seriously into music. The other area to look at is external cables near and around the PC - tidy them up and avoid power cables running parallel to sound cables. (you know how some people strap them all together to look neat - wrong! as far as audio goes)
Loud buzz when outputting audio only
By joelkranz in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 15th Mar 2014, 23:12 -
Audio replaced with buzz following encoding
By mycatsnameis in forum ffmpegX general discussionReplies: 9Last Post: 23rd Nov 2009, 19:45 -
How to filter out a ground buzz
By pdx10 in forum AudioReplies: 4Last Post: 24th Mar 2009, 10:14 -
cleaning up audio buzz?
By spiritgumm in forum AudioReplies: 1Last Post: 15th Apr 2008, 20:43 -
Removing Buzz in MP3
By ZeroX5 in forum AudioReplies: 16Last Post: 5th Jul 2007, 14:48
