Can somebody x-plane or kindly refer me to any source regarding what/which type of avi format I should use?
I just bought a TV Tuner/Capture card and it is listed a few type of avi compression that I can use.
1) RGB 555 (16 bit)
2) YUY2
3) YVU9
4) YV12
5) RGB 24
I usually capture TV Programs and Capture from my analog camcorder and convert them to VCD.
Please help. I'm new in this area.
mamushiraz
with rgb 24 you wont have any colour loss... but with yuy2 you will have a better performance. with an encoder like tmpgencoder you can correct the colours. so, i think you should use yuy2
For an explaination from some guy called Avery, using the name 'virtualdub' , go here:
http://arstechnica.infopop.net/OpenT...5&m=9060945491
Hell, I'll make it easy for you! Here is a copy of the most relevant bit (with all credit and blame directed at the original author!!!
A rough rundown on capture formats:
RGB32: The same quality as RGB24 with the bonus of 33% more useless data.
RGB24: Although twice the horizontal color resolution as YUY2, it tends to get produced by upsampling and thus with most capture devices you
won't get any additional quality by using it, just 50% more unnecessary data. However, it is by far the most compatible format when it comes to
codecs and encoders.
RGB16: Gives you the same data rate as YUY2 (1/3rd less than RGB24), but with significant banding. Good for video displays, bad for video
storage.
YUY2: In most cases, the best. It's usually the closest you can get to data right out of the video decoder and it offers significant speed and/or size
improvements over RGB24 (it's one-third smaller). This is the preferred format of Avisynth and Huffyuv. UYVY is a byte ordering change from YUY2
and either will do if both capture device and codec accept them.
YVU12 (YV12/I420): 25% less data than YUY2 in exchange for slightly more color bleeding vertically; this is the color space of MPEG-1. There is no
difference in luminance. Not very well supported, unfortunately, and I wouldn't use it even if you were targetting MPEG-1.
YVU9: 25% less data than YVU12 and 43% less data than YUY2, but significant color bleeding -- this is the color space of Indeo. Not very well
supported and I wouldn't recommend it.
Huffyuv is a lossless codec by Ben Rudiak-Gould that gives around 2:1 compression for decently clean source. Although it is slow at decompression, it has
very fast compression and is competitive with PICVideo MJPEG for high-quality capture. It gets significantly better compression with YUY2 or UYVY input
than with RGB. This is my method of choice, but it requires a LOT of disk space if you have a noisy feed -- something like 10GB per half hour for me, at
640x480x29.97fps with CD-quality audio.
As for PICVideo MJPEG, if you want universally compatible MJPEG (hardware devices and other software codecs) you need to set the codec to 4:2:2 color
space -- 1:1:1 and 4:1:1 are non-standard. You can also get better quality than the slider allows by clicking Advanced and dropping the quantizers even
lower. Finally, if you plan to do any field processing (adaptive deinterlace, IVTC) you should check the "two fields" box in the codec properties.
Sequencing my DV from Analog to AVI to iMovie. Format? Compression?
By kiararden in forum Video ConversionReplies: 4Last Post: 2nd Oct 2009, 10:20 -
TMPGEnc Products - Confuse?
By niteghost in forum Newbie / General discussionsReplies: 3Last Post: 20th Jul 2009, 17:12 -
I am Bit confuse with cd duplication..
By Sophias012 in forum Authoring (VCD/SVCD)Replies: 5Last Post: 4th May 2009, 17:36 -
Confuse about HDMI v1.3
By pwangdel in forum DVB / HDTVReplies: 3Last Post: 26th Nov 2007, 19:13 -
Best compression format for AVI's
By Smallan in forum Video ConversionReplies: 2Last Post: 19th May 2007, 18:13
Statistics
Newest guides
Latest tool updates
New media comments
