Hi Dears
I want to download a video which is streaming from mms protocol and has a *.wmv format.
I tried using VLC, Net Transport & many other programs to do it, but it didn't help and didn't work out.
for example i have a video link like this mms://media.iransima.ir/tv3/tv3_13901101_004.wmv
when i click this link in browser, it opens Windows Media Player and starts buffering and playing.
Anyone can help me, how to download this streaming video?
Thanks in Advance![]()
Results 1 to 9 of 9
The first thing that you should know is:
The stream located at mms://media.iransima.ir/tv3/........ has a special format. Microsoft defines this format as "playlist". The "playlist" format contains multiple streams which all have the same URL therefore they cannot be downloaded individually. One stream needs to be finished playing (or downloading) in order to access the next. The "playlist" format is rarely used.
2nd, You could download it with NetTransport. Take a look!!
The downloaded file information:
Amazing stream quality by Iranian!!Format : VC-1
Format profile : MP@HL
Codec ID : WMV3
Codec ID/Info : Windows Media Video 9
Codec ID/Hint : WMV3
Description of the codec : Windows Media Video 9 - Professional
Duration : 12mn 53s
Bit rate mode : Constant
Bit rate : 1 863 Kbps
Width : 720 pixels
Height : 576 pixels
Display aspect ratio : 5:4
Frame rate : 30.000 fps
Standard : PAL
VLC was able to download that wmv file.
Media -> Convert/Save
Network tab, enter mms:url, press Convert/Save
Enter file name for local file
Press the little tool button next toe the Settings/Profile.
Select ASF/WMV as the Encapsulation
Go to the Video Codec tab and select Keep Original Video Track
Go to the Audio Codec tab and select Keep Oringal Audio Track
Press Save
Press Start -
Thanks For Reply
Actually i did try to download with Net Transport, but all those Green logs (as in your image) was Red
for me, which mentioned that Net Transport couldn't download the file.
I just ran Net Transport (as administrator) and it did connect to server and downloaded file
Hello everyone!
Just joined the forum!
Thanks to dear Bahman for the solution! just wanted to suggest a little trick in NetTransport to take in account:
when adding new download, click "other settings" at right down corner, go to Streaming tab, under MMS section,set user agent to, click ok. you should get 2 download job, one with a size of 1.29MB or something and other with higher than 100MB in size!Code:WMPlayer/12.0.7601.17514 guid/3300AD50-2C39-46C0-AE0A-8BF52187E2C6
check the screenshot to confirm.
Normally, if you dont do this trick, the download process loops at downloading of "Ads" with size of 1,29 MB.
Hope this helps!
Enjoy fast download
What a useful trick!! Thank you!!
Hello all.
I'm trying to download some videos which use the mms protocol but nothing!
I have used 6-7 softwares, and all the ways described here!
this is one of the urls of the videos:
mms://pictron.museum.tv:80/MGWMS/MBC/TV%20Radio%20News/TV_01157/stream0.asf
Does anyone have any luck with that?Last edited by thinredline; 9th Dec 2012 at 12:46.
How to record streaming WMV/ASF/MMS-links using VLC Media Player
By Baldrick in forum User guidesReplies: 58Last Post: 27th Jul 2012, 10:10 -
Download Streaming Videos Without Quality Loss
By Eva-Unit01 in forum Video StreamingReplies: 6Last Post: 13th Sep 2010, 00:22 -
Want to download streaming online videos from websites
By vain in forum Video StreamingReplies: 3Last Post: 5th Dec 2009, 09:06 -
Anyone download the payware FUNimation episodes in WMV format?
By FulciLives in forum Video ConversionReplies: 2Last Post: 25th Aug 2008, 09:19 -
Capturing an image from a live stream video (MMS protocol)
By ali1977 in forum ProgrammingReplies: 0Last Post: 29th Nov 2007, 01:43
