    Hi all, I am trying to get some usable subtitles from a recorded TS stream using ProjectX. I can get subtitles fine but the time codes are completely wrong. I have deduced that it must be to do with the time of the recording is there anyway to reset the time codes to start from the beginning of the recording? That way say 10 seconds in to the recording the 10 second timecode kicks in? I have tried all sorts but can not fathom it. I even manaed to reset everything to zero at one point.
  2. All I had to do was tick an option that converts the subtitles into another format and then I could mux to MKV and it worked fine. Source: UK DVB-T MPEG2 TS files.
