Results 1 to 11 of 11
  1. hi
    i tried everything and followed all the things in the instructions
    but nothing is working with my Sony MHC-GNZ7D
    my dvd player read dvd divx, that's what written in the manuel
    but when i put divx, nothing
    it only plays dvd
    I need your help
    please
    Oct 2005
    666th portal
    one of those all in one things with speakers? they are about 6 years old and never played divx files.
    Sony MHC-GNZ7D Mini-System w/DVD
    100W x 2 RMS, 2200W PMPO
    3 DVD/VCD/CD Changer With MP3 Playback
    CD Tray Lock
    DVD-R/+R/+R DL/+RW/-RW/-RW(VR)/CD-R/RW Playback
    Jpeg Playback
    Progressive Scan (NTSC/PAL)
    Dolby Digital / DTS Decoder Built-in
    Component Out
    Centre Volume Knob With Illumination
    VACS
    Func: DVD/VCD/CD/Tuner/Tape - A/B/TV-Sat
    20 FM / 10AM Presets
    7 Preset Equaliser
    V-Groove/Groove
    Karaoke (Echo / Karaoke PON / Key Control)
  3. are you sure please
    but here the manuel http://pdf.crse.com/manuals/3094635131.pdf
    Oh My God if what you say is true, that's a big problem for me
    all my plans are gone
    I wanted to watch facebook and youtube videos
    Is there another format i can use with this to play it ?
    canada
    Post a media info of a divx file that won't play,might need to be re-encoded if isnt within spec.
  5. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Somewhere on VideoHelp...
    Originally Posted by derprinz View Post
    are you sure please
    If all else fails, you can try to create a DVD-Video disc from the videos using programs like AVS2DVD, DVD Flick, or FAVC (or for the shareware/commercial route, ConvertX2DVD).
    Aug 2006
    are you sure please
    Page 41 of the .pdf manual has some information that may be useful. It says:
    Only the version of your home theater system sold in Russia can play DivX files.
    The maximum resolution allowed is 720x576.
    The maximum file size allowed is 2GB.
    Files with more than 3 hours of video may not play.
    Files made by joining two or more DivX video files may not play.
    Some DivX files may play with poor video and audio quality.
  7. Originally Posted by johns0 View Post
    General
    Complete name : C:\Documents and Settings\amir.B47822EFBFF34E6\Bureau\test divx\test divx 756 virtualdub.avi
    Format : AVI
    File size : 734 KiB
    Duration : 8s 400ms
    Overall bit rate : 716 Kbps
    Writing library : VirtualDub-MPEG2 build 24586/release
    Video
    Format : MPEG-4 Visual
    Format settings, BVOP : 1
    Format settings, QPel : No
    Format settings, GMC : No warppoints
    Format settings, Matrix : Default (H.263)
    Muxing mode : Packed bitstream
    Codec ID : DX50
    Codec ID/Hint : DivX 5
    Duration : 8s 400ms
    Bit rate : 505 Kbps
    Width : 720 pixels
    Height : 576 pixels
    Display aspect ratio : 5:4
    Frame rate : 25.000 fps
    Standard : PAL
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 0.049
    Stream size : 518 KiB (71%)
    Writing library : DivX 6.8.5 (UTC 2009-08-20)
    Audio
    Format : AC-3
    Format/Info : Audio Coding 3
    Codec ID : 2000
    Duration : 8s 384ms
    Bit rate mode : Constant
    Bit rate : 192 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Bit depth : 16 bits
    Stream size : 197 KiB (27%)
    Alignment : Aligned on interleaves
    Interleave, duration : 42 ms (1.06 video frame)
    Interleave, preload duration : 512 ms
  8. Originally Posted by Ai Haibara View Post
    are you sure please
    i don't have a dvd writer
    can i convert it to VCD
    can you please help me with that
    i hear about it but don't know what is VCD actually
  9. thanks guys for your help
    Today i bought a cheap VD Tech DVD 602 dvd player ' without remote control'
    can i use a universal remote control ? i have supertel pilot
  10. And why does your location say "sony"?
  11. Originally Posted by TreeTops View Post
    i have a Sony MHC-GNZ7D that hast driven me crazy
