Using windows movie maker, how do I convert it to an mpeg to be able to put to VCD?![]()
TMPGEncoder it's free and it's in tools.I would use another capture
program the video quality in WMM is awful.
lampherem,
You're wasting your time and effort with Windows Movie Maker. It's a featureless, useless, confusing Windows utility in Microsoft's attempt to be all things to all people.
If your getting into video editing you're going to want to do more than Windows Movie Maker can achieve.
I would recommend VideoStudio 6.0 at www.ulead.com, it's not freeware about $100.00. If you browse and read this site many of the posts are regarding the same problems with the same software over and over and over again. You can do yourself a favor by starting out with a "real" video editing program. It will save you countless hours of frustration.
Just my opinion.
Good luck,
Gary Spicuzza
cic7@juno.com
have to say i disagree with other posts(if you only want to make a simple vcd movie in ok quality)im using win tv card with the booktree capture driver and ok the capture runs 30fps and 320-240 display ,which has to be converted , but on the up side little or no block noise, and no running out of hard drive. only good for vcd though
Trying to edit a movie on windows movie maker (Canon Vixia HF R20)
By Classic in forum EditingReplies: 1Last Post: 8th Mar 2012, 12:07 -
Windows Movie Maker crashes and won't puplish whole movie
By LoveMyslf in forum Video ConversionReplies: 27Last Post: 12th Dec 2009, 22:19 -
Blackmagic intensitiy, Capturing with Windows movie maker
By UnrealChrisG in forum CapturingReplies: 5Last Post: 12th Dec 2009, 16:02 -
windows movie maker
By c_paquette in forum Newbie / General discussionsReplies: 1Last Post: 7th Apr 2008, 14:51 -
DV-AVI widescreen 16:9 movie from Windows Movie Maker.
By bagb in forum Newbie / General discussionsReplies: 19Last Post: 12th Nov 2007, 10:37
Statistics
Newest guides
Latest tool updates
New media comments
