Page 4 of 12
FirstFirst ... 2 3 4 5 6 ... LastLast
Results 91 to 120 of 349
    Jun 2013
    USA
    Originally Posted by CristianoA View Post
    Originally Posted by diaz View Post
    i think you need to url with https not http or better use ffmpeg to download it
    ffmpeg -i "https://videos30ios-vh.akamaihd.net/i/1917_03152013_AFT_2013_DIR_ADM_AULA_01_Pt_I_ok.m...8b3e16da80a09e"-c copy t.ts
    How to do this? I'm using HttpFox Snifing for the traffic, but not found this line.
    check page source
    Thanks!!
  2. can anyone help me try to get this video off nbc.com plz
    I used Adobe HDS Downloader and keep getting this :/
  3. Originally Posted by angelroj7 View Post
    try use GetFLV newest version
    Mar 2012
    Singapore
    Hi, anyone can guide me on this.. i nb on php...
    i wan tto download this file
    http://madm.global.mnet.com/mnettv/videodetail.m?searchVideoDetailVO.clip_id=116680
  5. Originally Posted by harky View Post
    480p or 720p ?
    Mar 2012
    Singapore
    Hi 720p.
    480p or 720p ?
  7. This is only possible with INDIA proxy how-ever I have india vpn but my question is it looks like the dynamic streaming is encrypted is there anyway this can be downloaded ?
    http://tinyurl.com/mnnko4g
    Jan 2014
    netherlands
    Can you guys please help me I am trying to install and download adobehds
    I have downloaded the adobehds 5.5.9 in zip file. And the php file, all did it from https://github.com/K-S-V/Scripts/wiki
    sorry for my english
    I maked a new map in C:/ named in PHP,so c:/PHP put every file in the zip I have a 64bit windows 7 computer.
    so downloaded PHP 5.5 (5.5.9)VC11 x64 Non Thread Safe (2014-Feb-06 00:36:15) Note: x64 builds are currently experimental Zip [19.52MB]
    extracted in c:/PHP and the php file in the same folder
    and did the windows Environment Variables Path, putting the ;C:\PHP at the end.
    I open cmd
    type cd c:\ and it opens C. type php -v then...
    c:\>php -v
    PHP 5.5.9 (cli) (built: Feb 5 2014 11:04:12)
    Copyright (c) 1997-2014 The PHP Group
    Zend Engine v2.5.0, Copyright (c) 1998-2014 Zend Technologies
    soo its oke
    then type c:\>php adobehds.php --help
    and it saids Could not open input file: adobehds.php
    WHYYY
    I want to learn this adobehds you guys can give me little training with any website you want. With that frag seg things
    I have tried with websites in this in this tread. And even with live streaming websites like sport news and even aebn.net
    but it looks like the problem is already in the beginnen with that php adobehds.php --php
    please help me. I have tried a lot of thing different php.ini files manifest blabla.
    love this website. please help
  9. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    go here - https://github.com/K-S-V/Scripts
    right click on adobehds.php, "save link as", and save it into c:\php as "adobehds.php".
    no zip
    i believe you were supposed to also get php v5.4 not 5.5
    somewhere in the thread is a standalone version of adobehds.php that works.
    Jan 2014
    netherlands
    not worked, I have deleted in php map, downloaded ZIP... (((PHP 5.4 (5.4.25) VC9 x86 Non Thread Safe (2014-Feb-05 23:44:35)Zip [15.87MB]sha1: 6bca906c23fe0ce8abb42f0daca4bd464c781a69))) put the AdobeHDS.php inc C:\PHP so I get
    c:\>php -v
    PHP 5.4.25 (cli) (built: Feb 5 2014 21:19:32)
    Zend Engine v2.4.0, Copyright (c) 1998-2014 Zend Technologies
    And again
    tried also
    c:\>php adobehds.php --debug
    And
    c:\>php adobeHDS.php --update
    Could not open input file: adobeHDS.php
    I have windows 64bit and the 5.4 has no 64 bit version but that will not make a problem I think I had taken 5.4 VC9 x86 Non Thread Safe. put the adobehds.php that your given. https://github.com/K-S-V/ScriptsClick image for larger version
    so the php.ini file from https://github.com/K-S-V/Scripts/wiki is not placed this time. only your adobehds.php
    I have tried this with my computers and laptop. It gives the same problem... after c:\>php adobehds.php --help
    Could not open input file: adobehds.php.
    Jan 2014
    netherlands
    no zip
    Could not open input file: adobehds.php.Click image for larger version
  12. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    if you can't get it to work, go back through this thread and get the standalone version of adobehds.php it works fine, i've used it.
  13. You have to run that command from the c:\php folder, not the c:\ folder!
  14. I want to thank all of you who contributed in this thread! you are simply amazing. special thanks to user Chug a Bug who uploaded the HDS Downloader. I used it and in 10 seconds i've been able to download a protected video from a site i've been looking for months how to download from...
    Thank you very very much!
    Dec 2009
    Cyprus
    Can you help me how to download an encrypted video
    I am using HiDownload Platinum, version 8.23 but the program cannot download this video: http://www.megatv.com/megagegonota/summary.asp?catid=27377&subid=2&pubid=33249597
    The video file name is: manifest[1].f4m
    THANKS
  16. Originally Posted by neroman00 View Post
    THANKS
    http://www33.zippyshare.com/v/38559683/file.html
    Dec 2009
    Cyprus
    THANKS
    Thanks a lot but how you did it? what is the trick?
  18. Does the adobehds.php script decrypt an encrypted video? I am able to download all the videos that makeup a stream (each one is about 500K - 600K in size) but I have not been able to do anything with them. As such, I am assuming they are encrypted. I can't covert them and I can't view/play them. Would running the adobehds.php script against them take care of this? Is there any other alternative? Perhaps VideoGo or AnyVideoConverter?
    I have attached one file as an example, if that helps ... appears I can't include a f4f format file ... can I rename it to flv just to get it here?
    Thanks,
    Steve
  19. Deceased
    Dec 2007
    if the fragments are encrypted, adobehds.php will explicitly indicate that they have drm, is that what happened?
  20. I have not tried to use the adobehds.php as I do not have a php server setup. Not sure I want to go through that work but might if it is my only choice. Can it still get the file to a usable form even if it indicates drm?
    I did attached one of the files after renaming it with a .flv extention.
  21. Deceased
    Dec 2007
    It doesn't have drm. Here is the result after processing with adobehds.php;
  22. WOW ... Thanks! Is there any other way to convert it besides the adobehds.php script? I've try handbrake and another converter that claimed it would do f4f conversion ... neither of them would recognize the file.
    Thanks again .... at least I know something can be done with them.
    /Steve
  23. Originally Posted by honfoglalo111 View Post
    I have a similar problem but these solutions seems very difficult...
    So can anybody download this short video from this url? (It's a Hungarian news site)
    http://tv2.hu/musoraink/tenyek/4105_robotok_a_parkban.html
    I think there are fragments.
    You've written lot's of solution - is anyone of them working in this case?
    Please tell me, and I will try to learn that method.
    As shown in the testing picture below, it can be downloaded with StreamTransport.
  24. Originally Posted by neroman00 View Post
    THANKS
    You can follow this infographic.
    Tool: StreamTransport V1.1.2.0
    It requires to run on Windows 7 or lower with IE 10 or lower.
    https://fbcdn-sphotos-d-a.akamaihd.net/hphotos-ak-ash3/t1.0-9/1969128_762764837090317_...51237409_n.png
  25. Member
    Apr 2014
    Brasil
    Hello guys,
    Im new here.
    Ive tried all that stuff you guys recommend without sucess.
    Ive downloaded KSV Adobre HDS Downloader but the site where i want to download needs authentication. Ive a login/password but I cannot manage to put it at the program.
    Thats the error
    KSV Adobe HDS Downloader
    Processing manifest info....
    Access Denied! Unable to download manifest.
    Can someone help me?
    I was wondering why I cannot download the videos to my computer and them merge and convert to mp4/flv?
  26. Hi ,
    @Fra : Try this .
    php AdobeHDS.php --manifest "http://kalturahd-vh.akamaihd.net/z/content/r71v1/entry/data/290/98/0_5vechdzg_0_,9mv5u2y3,d2dlb7rb,gd7shrvg,v0tgycak,_1.mp4.csmil/manifest.f4m?g=SQSVMMKNUTPU&hdcore=3.1.0&plugin=aasp-3.1.0.43.124" --auth "als=0,3,NaN,0,0,NaN,0,0,0,33,f,0,206.68,f,u,SQSVMMKNUTPU,3.1.0,33&hdcore=3.1.0&plugin=aasp-3.1.0.43.124" --useragent "Mozilla/5.0 (Windows NT 5.1; rv:28.0) Gecko/20100101 Firefox/28.0" --delete
    Cheers .
  27. Hi ,
    @ggnobrega : Have a look at the main page .
    and /or
    http://forum.wiziwig.eu/threads/49818-Swiss-TV-%28German-French-Italian-English%29
    Have a look for "Adobe HDS Downloader/Viewer"
    ( the link for DL : http://www.mediafire.com/?fhefczcnt6ffdy4 )
    Regards .
  28. Member
    Apr 2014
    Brasil
    Originally Posted by aazerty View Post
    Hi ,
    and /or
    Regards .
    Hello @ aazerty
    I did all those steps, even at the first time, but I continue to get the error
    Where can I get the AUTH parameters? Its something related to authentication right?!
    Best regards
