  1. Hi all!
    Just tried playing with ffmpeg in making prores today.
    Was really happy with the new feature, worked for both Windows and Linux (Ubuntu 11.10)
    However, when I brought them back to my mac Final Cut Pro, I notice a slight color shift when compared to the original clip, seems like saturation was bumped up a bit. It is also apparent in the RGB Mixer scopes too.
    I tried using "-pxl_fmt yuv422p" and "-dct8x8" but none of them fixed the issue.
    Here is the command I entered: ffmpeg -i prores_test.mov -vcodec prores prores_test_output.mov
    And here is the info for both clips through ffmpeg:
    ORIGINAL CLIP
    ffmpeg version git-2012-01-05-7f83db3, Copyright (c) 2000-2012 the FFmpeg developers
    built on Jan 4 2012 17:58:18 with gcc 4.6.1
    configuration: --enable-gpl --enable-libfaac --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libtheora --enable-libvorbis --enable-libx264 --enable-nonfree --enable-postproc --enable-version3 --enable-x11grab
    libavutil 51. 34.100 / 51. 34.100
    libavcodec 53. 53.100 / 53. 53.100
    libavformat 53. 29.100 / 53. 29.100
    libavdevice 53. 4.100 / 53. 4.100
    libavfilter 2. 57.101 / 2. 57.101
    libswscale 2. 1.100 / 2. 1.100
    libswresample 0. 5.100 / 0. 5.100
    libpostproc 51. 2.100 / 51. 2.100
    Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'prores_test.mov':
    Metadata:
    major_brand : qt
    minor_version : 537199360
    compatible_brands: qt
    creation_time : 2012-01-04 21:32:19
    Duration: 00:00:03.00, start: 0.000000, bitrate: 168154 kb/s
    Stream #0:0(eng): Video: prores (apch / 0x68637061), yuv422p10le, 1920x1080, 166554 kb/s, SAR 1:1 DAR 16:9, 23.98 fps, 23.98 tbr, 23976 tbn, 23976 tbc
    Metadata:
    handler_name : ?Apple Alias Data Handler
    Stream #0:1(eng): Audio: pcm_s16le (sowt / 0x74776F73), 48000 Hz, 1 channels, s16, 768 kb/s
    Metadata:
    Stream #0:2(eng): Audio: pcm_s16le (sowt / 0x74776F73), 48000 Hz, 1 channels, s16, 768 kb/s
    Metadata:
    Stream #0:3(eng): Data: none (tmcd / 0x64636D74)
    Metadata:
    creation_time : 2012-01-04 21:32:24
    OUTPUTTED CLIP
    Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'prores_test_output.mov':
    Metadata:
    major_brand : qt
    minor_version : 512
    encoder : Lavf53.29.100
    Duration: 00:00:03.02, start: 0.000000, bitrate: 144974 kb/s
    Stream #0:0(eng): Video: prores (apcn / 0x6E637061), yuv422p10le, 1920x1080, 146154 kb/s, 23.98 fps, 23.98 tbr, 2997 tbn, 2997 tbc
    Metadata:
    handler_name :
    DataHandler
    Stream #0:1(eng): Audio: aac (mp4a / 0x6134706D), 48000 Hz, mono, s16, 83 kb/s
    Metadata:
    handler_name :
    DataHandler
    Anyone else run into this?
