    Hi,
    I'm putting episodes of a serie called ''Mag ik u kussen'' on a DVD.
    Season 1, was made out of downloaded AVI's, converted with ProCoder 3, imported to Encore. All good!
    Season 2, was made out of downloaded MKV's, tried to convert with ProCoder 3, but I get an error, 9 outta 10: [MPEG Importer] Failed to parse the stream. Stream seems invalid.
    The ones that ProCoder accepts, showing a faulty Duration and FPS (the episodes are 30 mins, with a framerate of 25 i think, tho ProCoder showing duration of 5 mins with a fps of 50 or 59.94.
    So I converted the MKV's with Freemake Video Converter 3.0.1.2 to MPEG.
    Loaded in the converted MPEG's into ProCoder (to convert them to m2v/wav) and all is good.
    Imported to Encore; making a cool menu, build a DVD-folder; burned them with Nero; Done!
    Season 3, was also made out of downloaded MKV's, ProCoder cant handle them either, so again converted them
    to MPEG with Freemake Video Converter.
    End result of the MPEG's, in sync no problems there.
    Tho... When I convert those MPEG's with ProCoder, and load them into Encore, the audio/video is outta sync.
    When I just import the MPEG's into Encore, it looks like it's in sync, but after burning the project to a DVD-folder, it's outta sync.
    Where does it go wrong?
    The MKV's all just play smooth with VLC and Windows Media Player.
    Is it a framerate issue perhaps?
    How do I know which framerate exactly is used in those MKV's?
    Thanks in advance!
    Note: I'm using Adobe Encore CS5.1
    To be more precise, there are 4 episodes in the Season 3, which are getting out of sync.
    When I look up the info in MediaInfo, the relating thing is that those are made with HandBrake 0.9.4.
    The other episodes made with other software in Season 3, actually staying in sync after converting.
    MediaInfo tells me the following info regard the 4 episodes:
    Episode 1 (getting out of sync):
    General
    Unique ID : 55962864378330034296258835456797824120 (0x2A1A0E3DA2D10CD19D1FA8573895D478)
    Complete name : E:\!Mijn Video's\Series\3 Mag Ik U Kussen - Seizoen 3 2011 - be\mkv\Mag.Ik.U.Kussen.S03E01 Svetlana Bolshakova.mkv
    Format : Matroska
    Format version : Version 2
    File size : 283 MiB
    Duration : 27mn 47s
    Overall bit rate : 1 422 Kbps
    Writing application : HandBrake 0.9.4
    Video
    Format : AVC
    Format profile : High@L3.1
    Format settings, CABAC : Yes
    Format settings, ReFrames : 3 frames
    Codec ID : V_MPEG4/ISO/AVC
    Duration : 27mn 47s
    Width : 720 pixels
    Height : 592 pixels
    Display aspect ratio : 16:9
    Frame rate : 25.000 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Writing library : x264 core 79
    Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.0:0.0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-2 / threads=6 / nr=0 / decimate=1 / mbaff=0 / constrained_intra=0 / bframes=3 / b_pyramid=0 / b_adapt=2 / b_bias=0 / direct=1 / wpredb=1 / wpredp=2 / keyint=250 / keyint_min=25 / scenecut=40 / rc_lookahead=50 / rc=crf / mbtree=1 / crf=20.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
    Language : English
    Default : Yes
    Forced : No
    Color primaries : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M
    Transfer characteristics : BT.709-5, BT.1361
    Matrix coefficients : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : A_AAC
    Duration : 27mn 47s
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Compression mode : Lossy
    Default : Yes
    Forced : No
    Episode 4 (getting out of sync, after conversion):
    General
    Unique ID : 67020985492638071449990286118181790657 (0x326BC5B48D6BF0F335B42C80FEFDE3C1)
    Complete name : E:\!Mijn Video's\Series\3 Mag Ik U Kussen - Seizoen 3 2011 - be\mkv\Mag.Ik.U.Kussen.S03E04 An Lemmens.mkv
    Format : Matroska
    File size : 300 MiB
    Duration : 26mn 13s
    Overall bit rate : 1 598 Kbps
    Video
    Format : AVC
    Format profile : Main@L3.0
    Format settings, ReFrames : 2 frames
    Duration : 26mn 13s
    Nominal bit rate : 1 422 Kbps
    Width : 706 pixels
    Height : 576 pixels
    Color space : YUV
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 0.140
    Encoding settings : cabac=1 / ref=2 / deblock=1:0:0 / analyse=0x1:0x111 / me=hex / subme=6 / psy=1 / psy_rd=1.0:0.0 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-2 / threads=6 / nr=0 / decimate=1 / mbaff=0 / constrained_intra=0 / bframes=2 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=0 / wpredp=2 / keyint=250 / keyint_min=25 / scenecut=40 / rc_lookahead=40 / rc=abr / mbtree=1 / bitrate=1422 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
    Language : English
    Default : Yes
    Forced : No
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : A_AAC
    Duration : 26mn 13s
    Default : Yes
    Forced : No
    Episode 8 (getting out of sync, after conversion):
    General
    Unique ID : 211149985932620009585822549705144271015 (0x9EDA0210A4B3CBCAB9B393A86C5E00A7)
    Complete name : E:\!Mijn Video's\Series\3 Mag Ik U Kussen - Seizoen 3 2011 - be\mkv\Mag.Ik.U.Kussen.S03E08 Véronique De Kock.mkv
    Format : Matroska
    File size : 303 MiB
    Duration : 29mn 24s
    Overall bit rate : 1 443 Kbps
    Video
    Format : AVC
    Duration : 29mn 24s
    Nominal bit rate : 1 269 Kbps
    Width : 712 pixels
    Height : 576 pixels
    Original display aspect ratio : 16:9
    Color space : YUV
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 0.124
    Encoding settings : cabac=1 / ref=2 / deblock=1:0:0 / analyse=0x1:0x111 / me=hex / subme=6 / psy=1 / psy_rd=1.0:0.0 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-2 / threads=6 / nr=0 / decimate=1 / mbaff=0 / constrained_intra=0 / bframes=2 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=0 / wpredp=2 / keyint=250 / keyint_min=25 / scenecut=40 / rc_lookahead=40 / rc=abr / mbtree=1 / bitrate=1269 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
    Language : English
    Default : Yes
    Forced : No
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : A_AAC
    Duration : 29mn 24s
    Default : Yes
    Forced : No
    Episode 13 (getting out of sync, after conversion):
    General
    Unique ID : 298748878360160471627888789832832795094 (0xE0C0F0E9DF0F7E2F4E3D5C1ECC4641D6)
    Complete name : E:\!Mijn Video's\Series\3 Mag Ik U Kussen - Seizoen 3 2011 - be\mkv\Mag.Ik.U.Kussen.S03E13 Jan Leyers.mkv
    Format : Matroska
    File size : 313 MiB
    Duration : 28mn 35s
    Overall bit rate : 1 533 Kbps
    Video
    Format : AVC
    Duration : 28mn 35s
    Nominal bit rate : 1 350 Kbps
    Width : 700 pixels
    Height : 576 pixels
    Color space : YUV
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 0.134
    Encoding settings : cabac=1 / ref=2 / deblock=1:0:0 / analyse=0x1:0x111 / me=hex / subme=6 / psy=1 / psy_rd=1.0:0.0 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-2 / threads=6 / nr=0 / decimate=1 / mbaff=0 / constrained_intra=0 / bframes=2 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=0 / wpredp=2 / keyint=250 / keyint_min=25 / scenecut=40 / rc_lookahead=40 / rc=abr / mbtree=1 / bitrate=1350 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
    Language : English
    Default : Yes
    Forced : No
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : A_AAC
    Duration : 28mn 35s
    Default : Yes
    Forced : No
    Instead of using Freemake Video Converter, I now used Format Factory , and... Tadaa! No out of sync issues nomore
