Hey
I'm the new guy, so I don't know a whole lot about this stuff, but I'm, trying and I',m learning.
I have a few films that consist of 2 iso-files and I would like to merge them, so each of them consist of 1 file.
Is this possible without to much hassle?
As mentioned above depends on what they are. If they are a DVD ISO a good and easy place to start might be with DVD shrink. It is a readily avail and free program. Without any effort it will accept DVD ISOs and it has the ability to accumulate them into I file.
Tony -
Hey
Sorry I've been outa town for at few days.
I have some old movies that are on 2 dvds each.
Example: Ben Hur from 1959 - 2 dvds
At the end of dvd 1 you get a sign saying "INTERMISSION" as it did in Movie Theaters back then (yes, I'm that old)
Dvd 2 begins with "ENTR'ACTE" (French for "between the acts") and then then 2nd part of the movie rolls.
I can esasily maually do this on my Popcorn Hour A-300. But I would very much like to make a seamless merge.
Is this enough info for you to help me, please.
Thanks. -
Unfortunately the movies I have left won't work with DVD shrink:
"DVD Shrink encountered an error an cannot continue.
Invalid navigation structure"
Thanks anyway. -
Maybe you have to use fixvts to be able to open it in dvd shrink...you have to extract the iso first though.
I don't know any other dvd-video iso joiner. -
http://www.dimadsoft.com/dvdremake/
and you may need to use DVD Shrink after merging the 2 discs -
FIXTVS works like a charm. After running the dvd through fixtvs I can use DVD Shrink.
Thanks a whole bunch.
merge 2 subtitles files
By massimo.max in forum SubtitleReplies: 15Last Post: 29th Dec 2012, 02:35 -
How to merge avi files?
By mkvelidadon in forum Newbie / General discussionsReplies: 3Last Post: 26th Sep 2011, 02:25 -
Merge two FLV files
By goheadtry in forum Newbie / General discussionsReplies: 19Last Post: 16th Dec 2010, 21:34 -
merge two avi files
By Jorge in forum Video ConversionReplies: 4Last Post: 17th Feb 2010, 22:01 -
How can I merge two video files into one?
By DVDNewb in forum Newbie / General discussionsReplies: 24Last Post: 17th Mar 2008, 13:58
