Hi there,
i am looking for a tool like DivX Plus Converter, but with CUDA support.
easy to use, good quality an a bit faster then DivX plus Converter, it takes about 12 hours to convert a 15Gb fullHD movie.
The reason is simple, i want to stream movies from my laptop to my TV using the PS3 Media server but the Laptop is to weak to convert mkv "on the fly" while streaming.
So, if anyone knows a Tool that converts to *.DivX pleas share your knowlege.
With all the other tool i tryed i got files with *.avi but i canīt stream them .. so i need *.DivX
Thank You
Can't you play the movie directly with your laptop connected to your tv? Instead of streaming it.
And what happens when you stream avi with ps3 media server? .divx and .avi are just containers so it shouldn't really matter that much. -
if i try to stream the mkv, it a slideshow wit 0.5 FPS ...
and avi .. i am not sure ... have to convert ... later the day. have to work
thank you,
How to convert MKV to Divx
By Raven2260 in forum User guidesReplies: 37Last Post: 17th Mar 2010, 13:22 -
How to Convert a MKV to DivX Ultra
By Shishir in forum Video ConversionReplies: 13Last Post: 1st Aug 2009, 06:34 -
Convert MKV to AVI or DIVX
By ranosb in forum Video ConversionReplies: 4Last Post: 3rd May 2009, 21:59 -
i have some mkv vedio and i want to convert it to .divx
By The1One in forum Newbie / General discussionsReplies: 1Last Post: 23rd Aug 2008, 12:07 -
how to convert mkv to divx/avi without loosing its quality?
By noskid21 in forum Newbie / General discussionsReplies: 2Last Post: 2nd Sep 2007, 11:00
