what would be the best codec for exporting screencasts from camtasia studio to edit them in premiere pro cs3 ? is quicktime/apple animation the best one ? or are there better ones out there, that premiere supports ?
That depends on what the final format will be. That's the best one.
Why do you mention Apple animation? Because it's 15fps? That frame rate doesn't need to be maintained. The clip should be upsampled to the project settings.Last edited by budwzr; 25th Dec 2011 at 07:37.
no, because animation is the only "intermediary" format I know, that is why I've asked if there are others, or better ones than animation, and better suited for screencasts
the final, edited video, will be a .mkv with h264 and aac inside
but first I wanted to know if there are better alternatives to animation, to use as intermediary for exporting from camtasia and for exporting from premiere after editing, and then encode with staxrip
is lagarith better than apple animation for screencast videos ? or huffyuv ?Last edited by codemaster; 25th Dec 2011 at 08:02.
To export I use AVI (UT VIDEO CODEC). Its easy editable on CS3.
Claudio
@ Cauptain: exactly what I was looking for, thanks, first time I hear about UT
do you know if UT is more stable than Lagarith, in Premiere Pro CS3 ? -
The codec is MultThread and work very well in high resolutions (1080p@60fps) on Sony Vegas. Never get trouble using UT Codec.
Ah my all records are make with UT Video (suggestion from another "vh" member JAGABO)
ClaudioLast edited by Cauptain; 25th Dec 2011 at 09:12.
What format u recommend i convert to for editing?
By vannhat in forum EditingReplies: 4Last Post: 25th Nov 2010, 17:16 -
VLC Format Movie Editing Help
By helpmepls in forum Newbie / General discussionsReplies: 6Last Post: 30th Oct 2008, 17:58 -
What's a good intermediary format?
By sd_smoker in forum Video ConversionReplies: 3Last Post: 9th Jul 2008, 12:06 -
recommend a video editing format
By contech in forum EditingReplies: 17Last Post: 12th May 2008, 15:39 -
Editing footage in MPEG-2 format
By RuckusVideo in forum EditingReplies: 6Last Post: 31st Jul 2007, 09:36
