  1. I am trying to record programming from my Scientific Atlanta explorer 8300hdc cable box to my pc via fire wire. I downloaded the recommended package and installed them. Device manager has no "!" points so it seems to be happy with the drivers. The "Transport Screen Capture" program runs until I hit the record button. I then get the error 800705AA: cannot start capture. This is as far as it lets me go; what can I try next?
    Thanks hoader
  2. BuskerAlley.com zoobie's Avatar
    Feb 2005
    Colorado Rocky Mountains
    Perhaps start by filling out your computer specs here.
    Are you sure it runs on your OS?
    Check this link
  3. Zoobie. thanks for responding so fast. I thought my computer info was available to you when I registered at this forum.
    Here is some computer info:
    Item Value
    OS Name Microsoft Windows XP Professional
    Version 5.1.2600 Service Pack 2 Build 2600
    OS Manufacturer Microsoft Corporation
    System Name KILLROY
    System Manufacturer HP Pavilion 061
    System Model RC652AA-ABA a1610n
    System Type X86-based PC
    Processor x86 Family 15 Model 75 Stepping 2 AuthenticAMD ~2204 Mhz
    BIOS Version/Date Phoenix Technologies, LTD 3.07, 8/2/2006
    SMBIOS Version 2.4
    Windows Directory C:\WINDOWS
    System Directory C:\WINDOWS\system32
    Boot Device \Device\HarddiskVolume1
    Locale United States
    Hardware Abstraction Layer Version = "5.1.2600.2180 (xpsp_sp2_rtm.040803-2158)"
    User Name KILLROY\George
    Time Zone Eastern Standard Time
    Total Physical Memory 1,024.00 MB
    Available Physical Memory 156.84 MB
    Total Virtual Memory 2.00 GB
    Available Virtual Memory 1.96 GB
    Page File Space 2.26 GB
    Page File C:\pagefile.sys
    I am running a small home network so it has to be running on my OS
    I checked the link you listed and it works up to the press record button. It lists Scientific-Atlanta AV/C Tuner Device (unknown video #1) in the capture device box.
    My installation went differently tha=en what was listed at this link. I downloaded the driver package, expanded it to a temp folder, and pointed the driver wizard to that folder for every driver and not just the "Tuner AV/C Device" or "Tuner AV/C Panel". It doesn't ask for any drivers when the computer reboots and none of the devices were disabled.
  4. BuskerAlley.com zoobie's Avatar
    Feb 2005
    I saw something in that same link about XP and flubbing up when the record button was hit.
    Did you happen to download one of those codec packs which aren't recommended?
    Sometimes, they conflict with programs.
    PS - Your computer specs can go in your profile for future reference.
  5. That link took me to a search list of lots of problems. I am a mechanic often troubleshooting agricultural equipment. I really hate it when the symptoms change. I did nothing to the drivers yet when I hit the record button, a timer starts counting down from 10 minutes and it starts a file with 12-x digits.mpg None of the other boxes have anything in them. I looked in 'device manager' under 'imaging devices' and found the following:
    Scientific-Atlanta AV/C panel device explorer 8300HD
    version 1.0.130.1430
    Scientific-Atlanta AV/C timer device explorer 8300HD
    Unknown IEEE 1394\5068 device
    imaging device
    Matsushita Electronics Industral
    device status no drivers are installed on this device
    Unknown IEEE 1394\989 device
    imaging device
    I can find these .mpg files and the longer I recorded, the larger they are. I use LVC media player for most viewing but it crashes when I try to open these .mpg files. What happened here? What driver is recommended with my configuration?
