I am trying to create a AVCHD usb file from a blu-ray backup I made. I would like to play the blu-ray backup from my external hard drive (Fat 32) using the ps3 system. The blu-ray backup I have has 2 folder...BDMV and CERTIFICATE. The total size of the blu-ray back up is 36.3 GB..
The problem is when I import the blu-ray folder to MultiAVCHD it is showing the total size as 332434 MiB (324.624 GiB) and the estimated output is 367138 MiB (358.533 GiB) / Duration 28:37:10
This is confusing and doesn�t make sense... as you can see the original file is only 36.3 GB but the MultiAVCHD is reading it as 10x bigger size and the output is also 10x bigger..
I did carry out the task assuming it will correct itself but it didn�t...the filesize started to grow more than 80 gb.. so I stopped the process..
It's looks like I am missing something very important please help..thx![]()
Results 1 to 1 of 1
No Audio on PS3 with MultiAVCHD
By Exaile in forum AudioReplies: 5Last Post: 7th Apr 2012, 17:14 -
Convert a .mp4 into an AVCHD file with multiAVCHD for a BD player?
By Falco21 in forum Video ConversionReplies: 13Last Post: 7th Mar 2011, 21:39 -
Problem converting bluray into split avchd (for hdd fat32 and ps3)
By Ale_Strife in forum Blu-ray RippingReplies: 5Last Post: 18th Feb 2011, 04:04 -
Creating avchd dvd from .mov file
By Mike L:isi in forum Authoring (Blu-ray)Replies: 16Last Post: 6th Aug 2009, 11:14 -
Steps to convert BDMV to AVCHD: data disc problem with PS3
By devilcoelhodog in forum Authoring (Blu-ray)Replies: 0Last Post: 12th Jan 2009, 19:53
