Is it TMPGenc or just me? It seem that since I've installed the updated version, I can't convert most of the downloaded avi files to mpeg anymore. I keep getting a unrecognized file type error, :oops: I downloaded the older divx 3.11 codec, but that didn't help either.
The problem is most likely with the audio, not the video. To quote their forums, Tmpgenc "DOESN'T DO MP3," which is what the audio in these newfangled avis is saved as.
Here's how to get around it, the ordained-by-God-Reverend-Jake way:
1) Download and install VirtualDub.
2) In VD (bad acronym, I know), open up your avi file.
3) On the audio tab, choose "full process." Under "conversion," make sure it's saving as an uncompressed .wav.
4) Go to the "file" menu, and choose "save as WAV."
This'll separate the audio from the file into a separate wav file on your HD. Then, in Tmpgenc, choose your avi file as the video source and the wav file as the audio source.
Not only did this get rid of the "unrecognized file type" errors for me, but it fixed some nagging sync issues I'd been having.
Hope this helps!
If you can play the avi's, you may want to try going into Tmpgenc, underOption, Environmental setting. Go to VFAPI plugin, you will want to note the current settings, hold your mouse over the names and look for the ones that deal with avi's - you will get a yellow popup window to tell you what tht name deals with, try raising the priority on one of the ones for avis and try again. I am not sure which you will need to raise, but you could try the directshow one first - raise it so it has the highest number.
Another thing is, are the avi's encoded with ac3? If so, you will need to find a plugin for that.
Need to supply "File Type" and "Mime Type" info for MKV file
By oneking in forum Newbie / General discussionsReplies: 9Last Post: 9th Feb 2012, 03:31 -
How to convert a trp type file to Mpeg2 type?
By Jemes-bs in forum Video ConversionReplies: 2Last Post: 13th Oct 2010, 15:59 -
MPEG Layer 2 video file, is it an editor friendly file type?
By ferran275 in forum Video ConversionReplies: 18Last Post: 16th Apr 2010, 23:41 -
unrecognized file?
By ninesixfour in forum ffmpegX general discussionReplies: 4Last Post: 10th Nov 2009, 13:10 -
Unrecognized .avi file
By dvm8600 in forum ffmpegX general discussionReplies: 11Last Post: 5th Mar 2009, 17:06
Statistics
Newest guides
Latest tool updates
New media comments
