Hi,
I have recorded video from vhs player through mpeg hardware encoder.
The final movie size(mpg) is about 8 GB. So, I thought It will be ease to split it on 2 dvd.
However PD in high quality mode (when creating vob files) needs about 11 GB!
I have choosen Smart Fit for the half of the movie, but I think that the final product's
quality is lower the original recorded file.
Why is that? Or should I use another better DVD authoring tool?
Is your mpg dvd compliant? See www.videohelp.com/dvd#tech and identify the mpg settings with mediainfo.
If so then should you be able to author it without reconversion. Maybe not with PowerDirector but with tmpgenc authoring works or some free author app like dvdstyler, guifordvdauthor, dvdflick(be sure to select not convert dvd mpg compliant video). -
very few professional authoring software has copy - no re-encode mode, most of them re-encode.
two main resons for size increase
1) PD might have re-encoded source video to higher bit-rate.
2) padding while convering mpg-to-vob.
if your source mpg is dvd compliant, try using avstodvd, dvdflick on short-small-sized sample and compare same with PD.Last edited by Bonie81; 22nd Dec 2011 at 18:16.
Does the tmpgenc authoring works have an option: "not convert dvd mpg compliant video"? If yes where can i find it?
MPG File Size and/or Timing Help
By GearBeer in forum Newbie / General discussionsReplies: 5Last Post: 28th Aug 2009, 11:21 -
DVD Rip Final Size Differs
By brvignesh in forum DVD RippingReplies: 7Last Post: 10th May 2008, 10:40 -
mpg to dvd keep file size
By bladerunnerx_x in forum Newbie / General discussionsReplies: 10Last Post: 9th Sep 2007, 13:12 -
Reducing mpg file size
By sknox in forum MacReplies: 2Last Post: 3rd Jul 2007, 04:41 -
larger file size from .avi to h264
By sai351 in forum Video ConversionReplies: 3Last Post: 4th Jun 2007, 13:20
