I'm trying to burn one of my movies onto a DVD5 disc and I keep getting an error. I know the DVD is good and the tray is clean. I even tried multiple blank discs and still no luck. Is this the fact that the file is a little over the size limit? ImgBurn Calculator reads 101% which is a little over the disc size. I decided to change the burn speeds down from AWS(max) down to 4x to even 2x and still no luck.
Here is the full log:
I 03:21:24 ImgBurn Version 2.5.6.0 started!
I 03:21:24 Microsoft Windows 7 Home Premium x64 Edition (6.1, Build 7601 : Service Pack 1)
I 03:21:24 Total Physical Memory: 2,095,672 KB - Available: 1,027,968 KB
I 03:21:24 Initialising SPTI...
I 03:21:24 Searching for SCSI / ATAPI devices...
I 03:21:24 -> Drive 1 - Info: PIONEER DVD-RW DVR-107D 1.18 (E(ATA)
I 03:21:24 -> Drive 2 - Info: ELBY CLONEDRIVE 1.4 (F(SCSI)
I 03:21:24 Found 1 DVD±RW and 1 BD-ROM/HD DVD-ROM!
I 03:21:31 Operation Started!
I 03:21:31 Building Image Tree...
I 03:21:31 Calculating Totals...
I 03:21:31 Preparing Image...
I 03:21:31 Contents: 98 Files, 16 Folders
I 03:21:31 Content Type: BD Video
I 03:21:31 Data Type: MODE1/2048
I 03:21:31 File System(s): UDF (2.50)
I 03:21:31 Volume Label: [Not Configured]
I 03:21:31 Size: 4,735,027,810 bytes
I 03:21:31 Sectors: 2,312,077
I 03:21:31 Image Size: 4,736,385,024 bytes
I 03:21:31 Image Sectors: 2,312,688
I 03:21:31 Operation Successfully Completed! - Duration: 00:00:00
I 03:21:46 Operation Started!
I 03:21:47 Building Image Tree...
I 03:21:48 Calculating Totals...
I 03:21:48 Preparing Image...
I 03:21:48 Contents: 98 Files, 16 Folders
I 03:21:48 Content Type: BD Video
I 03:21:48 Data Type: MODE1/2048
I 03:21:48 File System(s): UDF (2.50)
I 03:21:48 Volume Label: AVCHD_28 Days Later [2002]
I 03:21:48 Size: 4,735,027,810 bytes
I 03:21:48 Sectors: 2,312,077
I 03:21:48 Image Size: 4,736,385,024 bytes
I 03:21:48 Image Sectors: 2,312,688
I 03:21:49 Operation Successfully Completed! - Duration: 00:00:02
W 03:21:55 User accepted disc space warning and is attempting to overburn!
I 03:21:55 Operation Started!
I 03:21:55 Source File: -==/\/[BUILD IMAGE]\/\==-
I 03:21:55 Source File Sectors: 2,312,688 (MODE1/2048)
I 03:21:55 Source File Size: 4,736,385,024 bytes
I 03:21:55 Source File Volume Identifier: AVCHD_28 Days Later [2002]
I 03:21:55 Source File Volume Set Identifier: 3F851AB70023493D
I 03:21:55 Source File Application Identifier: ImgBurn v2.5.6.0
I 03:21:55 Source File Implementation Identifier: ImgBurn
I 03:21:55 Source File File System(s): UDF (2.50)
I 03:21:55 Destination Device: [1:0:0] PIONEER DVD-RW DVR-107D 1.18 (E(ATA)
I 03:21:55 Destination Media Type: DVD-R (Disc ID: RITEKF1)
I 03:21:55 Destination Media Supported Write Speeds: 1x, 2x, 4x
I 03:21:55 Destination Media Sectors: 2,298,496
I 03:21:55 Write Mode: DVD
I 03:21:55 Write Type: DAO
I 03:21:55 Write Speed: 4x
I 03:21:55 Link Size: Auto
I 03:21:55 Lock Volume: Yes
I 03:21:55 Test Mode: No
I 03:21:55 OPC: No
I 03:21:55 BURN-Proof: Enabled
I 03:21:55 Write Speed Successfully Set! - Effective: 5,540 KB/s (4x)
I 03:21:55 Advanced Settings - Optimal Writing Speed: No
E 03:21:59 Failed to Reserve Track! - Reason: Logical Block Address out of Range
E 03:22:00 Operation Failed! - Duration: 00:00:04
I 03:22:00 Average Write Rate: N/A - Maximum Write Rate: N/A
Yes, that is probably the issue here. ImgBurn is complaining that you are trying to overburn this disk.
What type of audio do you have in this AVCHD movie? You might be able to reduce the size of the audio by using a smaller bitrate AC3 using ClownBD and have an overall smaller file to burn to your disk. ClownBD allows 192 or 448 bitrate for AC3. -
Do you even have to ask? And this after you were warned even before beginning the burn, which would have saved some coasters had you heeded the warning.
W 03:21:55 User accepted disc space warning and is attempting to overburn! -
You're not using very good discs either, so I would strongly suggest that you not push the exact size limit of the DVD when burning or you're likely to experience errors at the very end of the burn as your writer writes to the outer edges of the disc. If you want to push the exact size boundaries of a single layer DVD then you're going to need to buy either the good quality Verbatim (NOT their Life series) or Taiyo Yuden discs.
We have lost the "Logical Disk Management" service
By mysts in forum ComputerReplies: 2Last Post: 24th Mar 2011, 07:43 -
Help please RE "Full Range" focus on Sanyo Xacti HD2000
By SchnauzerPup in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 13th Feb 2011, 10:33 -
"Unsynched repair block" on 1080i .TS HDTV file
By Pliny in forum DVB / IPTVReplies: 1Last Post: 13th Jun 2008, 03:57 -
Clonedvd error"invalid block start code"
By demonwarrior in forum Newbie / General discussionsReplies: 2Last Post: 6th Aug 2007, 06:01 -
Upgraded to ImgBurn 2.2 - Now "ImgBurn Shell Ext" No Longer Works
By Cool Breeze in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 11th May 2007, 11:05
(ATA)
