hi all
i find this on youtube http://www.youtube.com/watch?v=Nd5Ighxa1JM&feature=related
and have question
what best video codec pack for edius6 In all respects \ speed\decoding\encode\realtime\render ....etc
i have laptop i5 2.5 6gb ram win7 64bit
thanks
Results 1 to 11 of 11
The best codec pack is no codec pack. Install only the file readers, splitters, and codecs you need.
Quicksync is a mediocre encoder.
http://www.behardware.com/articles/828-27/h-264-encoding-cpu-vs-gpu-nvidia-cuda-amd-st...-and-x264.html
x264 with the veryfast preset is faster and better quality than Quicksync if you have a quad core CPU. -
If you have to ask what "codec pack" to use with a professional NLE like Edius, you've probably just pirated it instead of buying it. No sane Edius user would sully his or her system with random codecs from any "pack".
Installing K-lite is about as crazy as purposely installing a trojan, worm, virus or similar exploit.
It's just going to screw up your system.Want my help? Ask here! (not via PM!)
What is the best Codec Pack?
By cim in forum Software PlayingReplies: 84Last Post: 8th Jul 2012, 11:45 -
Klite Codec Pack
By pepegot1 in forum EditingReplies: 1Last Post: 27th Jan 2012, 13:44 -
64-Bit Vegas Pro 9 fails to open 64-bit UT Video Codec Pack
By Smells_Like_Feet in forum EditingReplies: 1Last Post: 2nd Oct 2011, 15:14 -
Best Codec Pack for wide variety of video player
By cutefix in forum Newbie / General discussionsReplies: 1Last Post: 18th Nov 2009, 23:25 -
Codec Pack selection?
By therock003 in forum Newbie / General discussionsReplies: 4Last Post: 21st Oct 2007, 10:50
