Results 1 to 20 of 20
    Jul 2008
    Brazil
    Hey guys!
    I have some .ts HD videos here (720 and 1080) and I wanted to tag them with my logo, but I don't want to loose quality. What's the best way to do it? I tried to do it and exported the video in mpeg2, but the file size increased a lot. How to keep the same size and tag it?
    Thanks!
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Adding a logo requires re-encoding and you will lose quality.
    Jul 2008
    Brazil
    Yeah, I imagined that... so what's the best solution to not lose that much quality and have a "small" file? (I mean small like around 500mb or less)
  4. Something with h.264 encoded video.
    Sep 2007
    h.264 really compresses the video files. Won't that make you LOSE quality. For example, I have a m2ts video file that I recorded (using my panasonic HD camcorder) that is 258MB and after converting to H.264 the file size dropped way down to 9.6MB! That HAS to decrease the quality, correct?
  6. When the OP says he exported it as MPEG2 and the file size increased "a lot"...well, that makes me suspect the original videos are probably encoded as h.264. Which a lot of high definition video is now. But he hasn't given any specifics.
    You want to keep the same size? I'd say h.264 then, it's very efficient. And any lossy compression will have a cost in quality regardless.
    Pull! Bang! Darn!
  7. All lossy codecs will result in a loss of quality. If you use sufficient bitrate the loss may be acceptable. The process involves first decompressing the original video then compressing it again with the new codec.
    As far as file size is concerned:
    file size = bitrate * running time
    Truly lossless codecs deliver very large file sizes (assuming you're starting with a compressed video). For example, say you have an hour long 1920x1080 30 fps video that's h.264 compressed at 20 Mb/s. That's about a 9 GB file. If you decompress that to uncompressed RGB it will balloon up to about 670 GB. If you then use a lossless compression codec you will get something around 200 to 300 GB.
    Sep 2007
    Ok, I am sure the codec used by my Panasonic HD is h.264, but why then I convert it to h.264/mp4 does it compress it even way further?
    Here is the properties from my source and the output.
    SOURCE:
    General
    Complete name : C:\Users\Daddy's HP Laptop\Videos\10-20-2011\10-20-2011_171020.m2ts
    Format : BDAV
    Format/Info : Blu-ray Video
    File size : 259 MiB
    Duration : 1mn 24s
    Overall bit rate : 25.7 Mbps
    Maximum Overall bit rate : 28.0 Mbps
    Video
    Menu ID : 1 (0x1)
    Format : AVC
    Format profile : High@L4.2
    Format settings, CABAC : Yes
    Format settings, ReFrames : 4 frames
    Format settings, GOP : M=3, N=30
    Codec ID : 27
    Duration : 1mn 24s
    Bit rate mode : Variable
    Bit rate : 24.5 Mbps
    Maximum bit rate : 26.0 Mbps
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate : 59.940 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.197
    Stream size : 245 MiB (95%)
    Audio
    Menu ID : 1 (0x1)
    Format : AC-3
    Format/Info : Audio Coding 3
    Codec ID : 129
    Duration : 1mn 24s
    Bit rate mode : Constant
    Bit rate : 256 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Bit depth : 16 bits
    Compression mode : Lossy
    Delay relative to video : -34ms
    Stream size : 2.57 MiB (1%)
    Text
    Menu ID : 1 (0x1)
    Format : PGS
    Codec ID : 144
    Duration : 1mn 23s
    OUTPUT:
    General
    Complete name : C:\Users\Daddy's HP Laptop\Videos\10-20-2011_171020.mp4
    Format : MPEG-4
    Format profile : Base Media
    Codec ID : isom
    File size : 10.8 MiB
    Duration : 1mn 23s
    Overall bit rate : 1 074 Kbps
    Encoded date : UTC 2011-12-03 03:37:13
    Tagged date : UTC 2011-12-03 03:37:13
    Writing application : Lavf51.12.1
    Video
    Format : AVC
    Format profile : Baseline@L1.3
    Format settings, CABAC : No
    Format settings, ReFrames : 1 frame
    Format settings, GOP : M=1, N=12
    Codec ID : avc1
    Duration : 1mn 23s
    Bit rate : 916 Kbps
    Width : 320 pixels
    Height : 240 pixels
    Display aspect ratio : 4:3
    Frame rate mode : Constant
    Color space : YUV
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 0.199
    Stream size : 9.17 MiB (85%)
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : 40
    Duration : 1mn 23s
    Bit rate : 152 Kbps
    Sampling rate : 44.1 KHz
    Stream size : 1.52 MiB (14%)
  9. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    You are making many spec changes* there.
    Start with what you are trying to accomplish? Small file sizes with crap quality?
    video bit rate 30% of original
    audio sample rate 48 to 44 CD
    http://www.kiva.org/about
  10. Originally Posted by jbitakis View Post
    According to that your source file was 259 MB and the file you made is 11 MB.
  11. Bit rate : 916 Kbps
    Width : 320 pixels
    Height : 240 pixels
    That is user error
    Sep 2007
    That is exactly my point. I know that going from an original source file size of 250mb down to 9mb will GREATLY decrease the quality. A small file size is NOT what I want. I want QUALITY HD VIDEO to be able to play on my bluray player WITHOUT things like the audio & or video stuttering happening.
    I just don't understand why when using Full video converter 9 software, when I choose HD h.264/mp4 or ANY of the HD conversions, the file size DRAMATICALLY decreases. When I choose the general video conversions, like AVI, DIVX, MKV etc. the file size and bitrate stay the same or increase. Is it something screwey with this software?
    I have figured out that if I slightly decrease the bitrate, from say 26 down to 23, the audio/video stuttering goes away and the quality is not decreased significantly. I just have to place these files into a different container (one that my bluray recognizes), like AVI or DIVX or MKV.
  13. Well you sort of hijacked the OP's thread... but anyway
    Maybe you used the wrong settings, or the software sucks ?
    Filesize = bitrate x running time
    Current blu-ray players do not have to support 1920x1080p59.94. It's not in the blu-ray spec. Just lowering the bitrate doesn't guarentee anything. Consider getting a HTPC or media player like wdtv, asus oplay instead. This way you don't waste time re-encoding, and don't lose any quality
  14. You will probably have to manually select the frame size (keep it 1920x1080), frame rate (60 fps), codec (h.264), and bitrate (24.5 Mb/s). That will give you the same file size without much quality loss.
    Jul 2008
    Brazil
    Thanks for all the replies...
    The software I'm using to tag the videos and reencode is Proshow Producer. The .ts file I wanted to tag is 300mb and after reencoding it with the tag, the exported mpeg2 was bigger than 1gb...
    Wich software would you recomend me to tag (watermark) the video and reencode it to h.264?
  16. Originally Posted by fabitos View Post
    Since the running time is the same: use the same bitrate if you want a file of the same size. But MPEG 2 will be lower quality than h.264 at the same bitrate.
    Sep 2007
    thanks. I am getting a WD TV Live Media player next week, so I will see how the m2ts 1920x1080 60P video files play.
  18. Some 1080p60 videos play well on my WDTV, some have problems. If you upload a sample I'll try playing it and let you know if it works.
  19. Member edDV's Avatar
    Mar 2004
    One issue I'm seeing with 1080 60p samples is they play for a few minutes, then lock up. It may be a device memory buffer issue. This happens even at reduced 17 Mbps bit rate.
  20. Originally Posted by jbitakis View Post
    just to give you heads up, new model WDTV Live streamer has still major issues regardless playback, I saw WDTV Live plus still on the shelf in Best Buy next to that new one WDTV Live streamer , it can give you some frustrating time before WD fixes that,
    Best Buy purchase gives you an opportunity to try it and exchange it or to return easily
