I have ripped my DVD collection to disk as ISO files. However, playing DVD ISO files is quite sluggish on my XBMC Atom/ION2 machines.
Playing back encoded 1080p x264 material in a proper container format does not seem to be a problem.
Now I'm looking for a method to encode all the ISO files in batch from the command line under Linux, presumably using ffmpeg or similar. It's important that all the video, audio, and subtitle tracks are included. Quality is more important than storage space.
I'm looking for options to specify to do something like:
ffmpeg -i MOVIE.iso -someoptions MOVIE.mkv
Possibly with a script wrapped around the commands to iterate over all tracks of ffmpeg can't do that itself.
Any ideas?
Results 1 to 17 of 17
Thread: DVD/ISO to MKV using ffmpeg?
Mencoder is better for dvd iso sources, google mencoder iso to avi for example.
Or MakeMKV, http://www.makemkv.com/forum2/viewtopic.php?f=3&t=224 , it doesn't reconvert the video at all, keeps the video in mpeg2 dvd and audio tracks, subs.
Both available for linux. -
Thank you for your reply.
I've also been looking at mencoder. My problem is googling for either ffmpeg or mencoder command line options is that most hits is for doing the oposite, e.g. converting downloaded media to ISO for burning DVD's. Or some subset of what I want like extracting a single track etc. I'm looking for a method to extract all tracks like I mentioned earlier.
Also when I've asked questions about mencoder I've been told to use ffpmeg as there is more active development around ffmpeg.
According to
http://en.wikipedia.org/wiki/Comparison_of_container_formats
Subtitles are supported "via third party modifications", hence I would rather use MKV as target format.
I've also tried makemkv previously, but after installing it (emerge mkvtoolnix under Gentoo) I just got a dialog box saying "Application failed to initialize" when entering either "makemkv" or "makemkv --help".
Most descriptions I find have long descriptions on how to extract a single track etc:
http://en.gentoo-wiki.com/wiki/Ripping_DVD_to_Matroska_and_H.264
But I was hoping to find something to find all the tracks and convert them. -
It seems like the command line version of the tool (which is only available as a binary) will do what I want:
Code:makemkvcon mkv iso:DVD_MDHK_PART1.iso all .
Even though it complains about that it "can't find any usable optical drives" it seem to work. -
I also tried to build handbrake (cli version) from source, but it seem to be a problem with my version of automake:
Code:./configure --disable-gtk --force cd build make ... autoreconf-2.68: configure.in: not using Gettext autoreconf-2.68: running: aclocal --output=aclocal.m4t am-wrapper: /usr/bin/aclocal-1.4 is missing or not executable. Please try emerging the correct version of automake. autoreconf-2.68: aclocal failed with exit status: 1 -
according to http://forums.gentoo.org/viewtopic-t-846845-start-0.html automake 1.4 should solve the problem, but it only leads to a different problem:
This might be the reason why there is no handbrake portage entry...Code:autoreconf-2.68: running: aclocal --output=aclocal.m4t aclocal: macro `_LT_DECL_SED' required but not defined aclocal: macro `_LT_FUNC_STRIPNAME_CNF' required but not defined autoreconf-2.68: aclocal failed with exit status: 1 make: *** [contrib/a52dec/.stamp.configure] Error 1
i hv gone thru' the link and details. Gentoo is known as tough tux. better to go through gentoo portage documentation for package building guidelines or there is nothing wrong ask/seek help from regular package builders coz open-source community is full of help. i never tried gentoo coz debian made me to fall for debian.according to http://forums.gentoo.org/viewtopic-t...5-start-0.html automake 1.4 should solve the problem, but it only leads to a different problem
Setting the environment variable
got a step further:Code:export WANT_AUTOMAKE=1.11
Next step is to find fribidi.h...Code:/bin/sh ../libtool --silent --tag=CC --mode=compile /usr/bin/gcc -DHAVE_CONFIG_H -I. -I.. -Wall -I/home/petter/handbrake.git/build/contrib/include/freetype2 -I/home/petter/handbrake.git/build/contrib/include -I/home/petter/handbrake.git/build/contrib/include -c -o ass_font.lo ass_font.c In file included from ass_font.c:35:0: ass_shaper.h:24:29: fatal error: fribidi/fribidi.h: No such file or directory compilation terminated. make[3]: *** [ass_font.lo] Error 1
[QUOTE=Bonie81;2124513]
But that's the source of the problem, there is no portage entry for handbrake in Gentoo. If it was I could have simply donebetter to go through gentoo portage documentation for package building guidelines
Also there is not a single maintainer for a handbrake ebuild, just a bunch of users trying to set one up, each one appears to run into different problems depending upon the version they try to build.Code:emerge handbrake
Installed fribidi and got a little step further:
Code:In file included from ass_font.c:35:0: ass_shaper.h:33:56: error: expected declaration specifiers or '...' before 'FriBidiParType' ass_shaper.h:39:16: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'resolve_base_direction' make[3]: *** [ass_font.lo] Error 1
I've downloaded HandBrake-0.9.5.tar.bz2 which will compile fine. The git version does not seem to contain any tags or branches and HEAD is probably not stable at all times.
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 11:19 -
Converting mkv to dvd always results in an oversize iso
By Akhet in forum Newbie / General discussionsReplies: 3Last Post: 24th Sep 2011, 23:16 -
Ghosting on MKV DVD rips. Rip to ISO instead?
By mpalm887 in forum DVD RippingReplies: 2Last Post: 3rd Mar 2011, 01:59 -
MKV To VIDEO_TS / ISO / DVD
By Valentin in forum MacReplies: 1Last Post: 31st Aug 2010, 20:13 -
MKV to DVD but become ISO instead
By c1steady in forum Video ConversionReplies: 2Last Post: 24th Apr 2009, 02:14
