I'm trying to cap some analog Hi-8 which could stand some stabilization. I was thinking about passing it through the Pan 1980p. Does anyone know if the 1980p's TBC will function on passthrough before I rerack and rewire a bunch of stuff?
Results 1 to 15 of 15
http://www.kiva.org/about -
The Panasonic 1980p being an SVHS deck with a field TBC. Sorry for thr confusion. I have a Sony Hi-8 deck I was going to pass through the Panasonic VCR in hopes to stabalize my fields.
magillagorilla the ag1980 Panasonic shvs doesn't have tbc passtrough function only on play ( not even on recording on the vcr ). You can use dvd recorder for passtrough which is excellent for hi8 cameras ( none of them as far as I know doesn't have any kind of tbc)I use it for mine and also as composite to svideo convertor its working great on pann dmr es15 and dmr e55
The AG-1980 doesn't have any pass-through TBC capabilities. It does have a very good comb filter though. The JVC HM-DH40000U however can be used as a pass through TBC. I don't know if the newer HM-DH5U and DT100U have the feature.
Toshiba DVD recorders can be used for TBC pass-thru. Most older Toshiba's also have a 3D-Y/C filter on all inputs (the Y/C doesn't function on s-video input, but the 3D comb function does). They also have input and output DNR, but don't depend on it: it's mostly a simple blurring filter. Older Toshiba recorders from RD-2 up to the RD-XS series have pretty much the same filter and TBC functions. With Panasonics, TBC is active on Line 1 only.
Our inventions are wont to be pretty toys, which distract our attention from serious things. They are but improved means to an unimproved end. -- Henry David Thoreau -
How about the Toshiba D-VR600?
You guys are awesome! I just put the Toshiba D-VR600 in the path and it totally fixed my field wobble. Thanks!Last edited by magillagorilla; 1st Dec 2011 at 19:56.
I've never seen the Toshiba line act as a passthrough, and I've used several of them. Only the Panasonic ES10-15 is really known for this. And then several JVC HM-DH40000U D-VHS VCR owners have discovered it has the ability, too. (Not surprising, since I believe JVC and Panasonic shared some tech for their VCRs, both being Matsushita brands.)
Have you considered just paying a service for the few tapes giving trouble, as opposed to reinventing the wheel yourself?Answers to Common Video Questions:
Best blank discs • Timebase Corrector FAQ • Best VCR for capturing • Help restoring video -
There are 23 tapes and they were all wiggly on the horizontal. But when I pass the signal through the Toshiba DVDR the scan lines are dead straight. Not really a need for a service. I'm no master at restoring but I'm pretty good at it and I can't afford to pay a shop for 23 tapes.
Also, off topic, normally I use HuffyUV for my capping codec. Because of the size of this project I am considering using DV for my caps. I have he codecia DV codec. Any recomendations on how to set it properly for Hi-8 footage? I am able to get it to work but I would like to make sure I am using optimum settings. -
Something must be amiss. My Toshibas have worked fine as TBC pass-thru, along with my Panasonic ES-20. I think the Toshibas are more effective (and have cleaner color and blacks than the Panny). I've used an old banged-up Toshiba RD-K2 and the RD-XS34. The TBC in the Toshiba seems to be active on all inputs -- I've only tried Lines 1 and 2, never tried Line 3. The Toshibas even help a little with chroma shift and red bleed on VHS. Both Toshibas have 3D-Y/C filters that can be enabled/disabled on composite inputs.
I have tested DVD Recorders from JVC, Lite-ON, Panasonic, RCA, Toshiba, Philips, and Magnavox. They ALL provided Frame Synchronization and some level of TBC performance via passthrough.
Life is better when you focus on the signals instead of the noise. -
Do you know if ag1980 can act as composite in/ svideo out ( with the benefits from svideo signal connection to the pc) just like connection and signal passtrough without tbc function. I tried to connect one with broken tape mechanism and i don't see difference between composite from camera direct in pc card and composite from camera in ag1980 and svideo signal out from vcr to pc cardThe AG-1980 doesn't have any pass-through TBC capabilities. It does have a very good comb filter though
Yes, the comb filter can be used like that. The difference is more noticeable when you have sharp text or computer generated graphics on the screen, usually you get dot crawl along the edges with a poor comb filter. Keep in mind that dot crawl might already be "baked in" to your videos if a poor comb filter was used to record them.
Panasonic AG-1980P vs JVC HR-S9800 / SR-V10U
By lordsmurf in forum RestorationReplies: 60Last Post: 5th Mar 2012, 23:12 -
Panasonic AG-1980P deck ejects all tapes.
By Spektre in forum CapturingReplies: 2Last Post: 7th Nov 2011, 23:34 -
Sony dcr-trv350 TBC and passthrough
By Regor21 in forum Camcorders (DV/HDV/AVCHD)Replies: 2Last Post: 9th Aug 2011, 20:06 -
Panasonic AG-1980P and TBC Questions
By icon in forum RestorationReplies: 6Last Post: 19th Dec 2009, 23:34 -
The TBC on my AG-1980P is making my videos look blocky.
By cowmix in forum CapturingReplies: 10Last Post: 20th Sep 2009, 16:32
