A DVDRip.Xvid.AC3 will not play in DVD on my standalone LG bd 350 Bluray player but will play on USB on that player and from the DVD drive of computer under VLC
Does anyone know why this is? File does not have Warppoints or Qpel. I can play it but am curious as to why it wil not play on the BD player
Here it is
General
Complete name : C:\Users\USERNAME\NAME OF FILE[YEAR].Dvdrip.Xvid.AC3[5.1]-NAME OF FILE[YEAR].Dvdrip.Xvid.AC3[5.1]-RoCK.avi
Format : AVI
Format profile : OpenDML
Format settings : rec
File size : 1.46 GiB
Duration : 2h 22mn
Overall bit rate : 1 465 Kbps
Writing application : AVI-Mux GUI 1.17.7, Aug 8 2006 20:59:17
Video
Format : MPEG-4 Visual
Format profile : Simple@L3
Format settings, BVOP : No
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 2h 15mn
Bit rate : 1 076 Kbps
Width : 720 pixels
Height : 336 pixels
Display aspect ratio : 2.2:1
Frame rate : 25.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.178
Stream size : 1.07 GiB (73%)
Writing library : XviD 1.2.0.dev47 (UTC 2006-11-01)
Audio
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : 2000
Duration : 2h 22mn
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Stream size : 392 MiB (26%)
Alignment : Aligned on interleaves
Interleave, duration : 64 ms (1.60 video frames)
Interleave, preload duration : 192 ms -
Offhand I'm not seeing anything in the file that stands out as a problem, but others will comment if I missed something. I would guess that either the LG simply doesn't support Divx playback from DVD or that it does but it has restrictions on the file system on the DVD. For example, maybe it will play Divx burned to DVD discs but you have to do the burn as ISO or ISO+Joliet and you did a UDF burn.
Hang on - I do notice that the video and audio have different durations by 7 minutes. That's definitely bad. I can't say that this is your problem but that's definitely bad. The video duration seems to be the wrong one. -
It's probably not the video as it works from the usb connection.
Can you select the avi from the blu-ray player? Or does it not list any files? If so how how do you burn the file? You might have to burn in mixed UDF/ISO mode.
And some blu-ray players does not support avi from cd/dvd/bd media.
edit:too slow... -
MKV DvdRip Xvid Downloads Play on WMP but wont play on my PVR
By dashas in forum Newbie / General discussionsReplies: 7Last Post: 25th May 2011, 05:15 -
Bluray player won't play avchd
By jayman13 in forum Authoring (Blu-ray)Replies: 5Last Post: 2nd Mar 2009, 12:22 -
[SOLVED]Audio won't play for an AVI file in my standalone DivX/XviD player!
By =CrAzYG33K= in forum AudioReplies: 4Last Post: 13th Oct 2008, 08:32 -
xvid video I burned onto cd won't play in dvd player
By dvdnewbie64 in forum Newbie / General discussionsReplies: 11Last Post: 5th May 2007, 18:45
