Hello everyone, I will explain a little bit about my problem so you understand a little more to what am having trouble with.
I back up my movies into my external hardrive by ripping them using DVDFab 8 Qt. I like to rip them with all their Audios and subtitles so they are complete. I mux the audios and the subtitles with the video and everything is playable fine in VLC. I connect my external hard drive to a Samsung TV to watch these movies. The audios are selectable, I can change from one audio to the other one, but the subtitles doesn't appear. I've tested with SSA and SRT format but nothing works. I used AviAddXSub software to add the subtitles from IDX/SUB and those subtitles work with the TV however this program delays the audio by a few seconds. I try to fix this with AviMuxGui but the subtitles doesn't show up. My conclusion was that the TV only reads subpictures subtitles, but AviMuxGui doesn't support these files. Samsung representative said the TV supports .ttxt, .smi, .srt, .sub, .txt. As i said before i test SRT but didn't work, so is it possible that there's a format SRT that contains subpictures?
Is there a way to rip the subpictures from the original DVD/BD? and if so, which software could be use to Mux it to the video?
for BD i use H.264 and MKV
for DVD i use H.264 and AVI
Thanks in advance.
I've been using AviAddXSubs for several years. I haven't noticed it delaying the audio.
The other thing you can do with AviAddXSubs, instead of muxing the subtitles into the video, just have it produce idx/sub files and name them with the same base name as the video. For example if the video is movie.mkv name the subtitle files movie.idx and movie.sub. Make sure all 3 files are in the same folder. I have a WD HDTV for USB and I create external idx/sub files from .srt all the time. The WD player has very limited settings for .srt. But by using AviAddXSubs to create idx/sub I can control the position, font, font size, and border thickness of the letters.http://milesaheadsoftware.org/
Fully enabled freeware for Windows PCs. -
Thanks for your responce. I notice that error wasn't from AviAddXSubs, maybe there was an error while ripping the video and it delayed the audios . I tried leaving the IDS/SUB files with same name in same folder as the video but the movie wouldn't read it that way. Today i tried doing same but with an SRT file and it works with the TV. just one problem., I can't rename 3 diferent subtitle files the same as the movie. Is it possible to store 3 subtitles in 1 file? Anyways thanks for the info, will try the other formats that are supported.
You can always rename them by adding corresponding language codes to the end of the files, just before the file extension. For example, rename the English subtitle file to Example.en.srt, Spanish to Example.es.srt, etc. If you have two subtitles of the same language, just use a random language code. Purpose of these codes is to display a language of the subtitle when changing it via remote. This method works on most of the DVD players.
You can also try VobSubMuxer as noted on the page for Txt2VobSub
http://www.trustfm.net/divx/SoftwareTxt2Vobsub.php?b2=1
The language code that Charmer suggested is easiest to try though.
The older divx capable DVD players didn't like multiple languages in one idx/sub set. My Philips 5990s don't mind. I don't know about Samsung TV though.http://milesaheadsoftware.org/
Ah I see, Well i think i will stick with the IDX/SUB muxing by AviAddXSubs. thanks for all your help miles and charmer.
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 11:19 -
mux multi mkv to mp4
By DKhanh in forum Video ConversionReplies: 4Last Post: 19th Nov 2011, 08:13 -
AVI-MUX: How do I mux avi file with a setting of "preload=512?"
By Stealth3si in forum EditingReplies: 3Last Post: 1st Feb 2010, 10:10 -
mux .sup subtitles in to .mkv Is this possible?
By sdk83 in forum SubtitleReplies: 3Last Post: 5th Nov 2008, 12:47 -
h264 + ac3... .mkv mux in synch, .avi mux out of synch...
By homerpez in forum Video ConversionReplies: 0Last Post: 5th May 2007, 05:42
