Results 1 to 9 of 9
  1. hi,
    i am from germany, i tryed to convert a mkv file to dvd with dvdflick, but get always the same error:
    DVD Flick error log
    Version 1.3.0.7 build 738
    Windows 6.1 build 7600
    *** Project info
    EncodeProf 2
    Threads 2
    OverScan 0, 3
    TargetRate 0
    TargetFormat 2
    TargetSize 4
    CreateISO 0
    CustRate 0
    EnableBurn 0
    EraseRW 1
    HalfRes 0
    LoopPlayb 1
    AutoPlayMenu 1
    MenuTemplt None
    VolumeMod 100
    WhenPlayed 0
    *** Warnings given
    *** Titles
    0 - VIDEO
        ChaptCount -1
        ChaptInt 10
        ChaptSource 1
        TargetAR 1
        ThumbIndex 634
    *** Project sources
        C:\Users\Denny\Downloads\VIDEO.mkv
        Stream 0 (2)
            Dur 6337,4
            StartT 0
            Compr h264
            BitR 0
            1280x536 23,976 FPS
            PAR 1
            SAR 2,38806
        Stream 1 (1)
            Dur 6337,4
            StartT 0
            Compr ac3
            BitR 0
            Chnnls 2
            SRate 48000
            Delay -160
        Stream 2 (1)
            Dur 6337,4
            StartT 0
            Compr dca
            BitR 0
            Chnnls 6
            SRate 48000
            Delay -160
    *** dvdflick.log
    10:02:38: DVD Flick 1.3.0.7 build 738
    10:02:38: Calculating stream sizes...
    10:02:38:     Disc space used : 4486879 KB
    10:02:38:     Average bitrate : 5803 Kbit/s
    10:02:38:     Total duration  : 1:45:37 hours
    10:02:38: 1 title(s).
    10:02:38: Using Normal encoding profile.
    10:02:38: NTSC-Film target format.
    10:02:38: CPU: Pentium(R) Dual-Core CPU       T4200  @ 2.00GHz
    10:02:38: Threadcount: 2
    10:02:38: Encoding video...
    10:02:38:     Title 0, source 0
    10:02:38:         Source         : C:\Users\Denny\Downloads\VIDEO\VIDEO.mkv
    10:02:38:         Properties     : 1280x536, 2,39:1, 23,976 FPS, h264, 6337,4 seconds
    10:02:38:         Target BitRate : 5803 Kbit\s
    10:06:06:         Re-encoding
    10:06:06:          -r 23.976 -i "C:\Users\Denny\Desktop\x\X2\mkvtemp" -vcodec mpeg2video -s 720x352 -padtop 64 -padbottom 64 -r 23.976 -g 14 -bufsize 1835008 -packetsize 2048 -muxrate 10080000 -aspect 16:9 -minrate 5753k -maxrate 5753k -b 5753k -preme 1 -precmp 2 -subcmp 8 -mbcmp 8 -cmp 1 -sws_flags lanczos+accurate_rnd -mbd 2 -sc_threshold -3000 -dc 8 -an -threads 2 -fflags +genpts -f mpeg2video -shortest "C:\Users\Denny\Desktop\x\X2\0.0.m2v"
    12:02:54: Combining video sources...
    12:02:54:         Concatenating video...
    12:02:54: Encoding audio...
    12:02:54:     Title 0, track 0, source 0 of 0
    12:02:54:         Source     : C:\Users\Denny\Downloads\VIDEO\VIDEO.mkv
    12:02:54:         Properties : 2 channels, 48000 Hz, ac3, 6337,4 seconds
    12:02:54:          -i "C:\Users\Denny\Downloads\VIDEO\VIDEO.mkv" -i "C:\Users\Denny\Desktop\x\X2\0.0.m2v" -map 0:1:1:0 -acodec copy -threads 2 -async 0 -shortest "C:\Users\Denny\Desktop\x\X2\0.0.0.ac3"
    13:17:30:         Fixing delay of -160 ms
    13:17:30:         -start -160 "C:\Users\Denny\Desktop\x\X2\0.0.0.ac3"
    13:17:30: 53 from dvdflick: Datei nicht gefunden
    *** ffmpeg_audio_title0_track0_source0.txt
    Last message repeated 6 times
    [NULL @ 0x26b1100]error, non monotone timestamps 570294720 >= 570294720
    [NULL @ 0x26b1100]error, non monotone timestamps 570317760 >= 570317760
    [NULL @ 0x26b1100]error, non monotone timestamps 570340800 >= 570340800
    size=  297066kB time=6337.38 bitrate= 384.0kbits/s
    video:0kB audio:297066kB global headers:0kB muxing overhead 0.000000%
    *** ffmpeg_video_title0_source0.txt
    e=151878 fps= 22 q=2.0 size= 4448531kB time=6334.54 bitrate=5753.0kbits/s
    frame=151896 fps= 22 q=2.0 size= 4449058kB time=6335.29 bitrate=5753.0kbits/s
    frame=151914 fps= 22 q=2.0 size= 4449585kB time=6336.04 bitrate=5753.0kbits/s
    [h264 @ 0x3ca0e0]missing picture in access unit
    frame=151919 fps= 22 q=2.0 Lsize= 4449732kB time=6336.25 bitrate=5753.0kbits/s
    video:4449732kB audio:0kB global headers:0kB muxing overhead 0.000000%
    *** mkvextract.txt
    gress: 99%
    Progress: 99%
    Progress: 99%
    Progress: 99%
    Progress: 99%
    Progress: 99%
    Progress: 99%
    Progress: 99%
    Progress: 99%
    Progress: 99%
    Progress: 99%
    Progress: 99%
    Progress: 99%
    Progress: 99%
    Progress: 99%
    Progress: 99%
    Progress: 99%
    Progress: 99%
    Progress: 99%
    Progress: 99%
    Progress: 99%
    Progress: 99%
    Progress: 99%
    Progress: 99%
    Progress: 99%
    Progress: 99%
    Progress: 99%
    Progress: 99%
    Progress: 99%
    Progress: 99%
    Progress: 99%
    Progress: 100%%
    *** Project destination folder
        0.0.0.ac3    304195584
        0.0.m2v    4556525183
        dvdflick.log    2229
        errorlog.txt    6574
        ffmpeg_audio_title0_track0_source0.txt    2853306
        ffmpeg_video_title0_source0.txt    1087923
        mkvextract.txt    58042
    *** Drives
        C - ACER - 2
        FS NTFS
        AvailSpace 146119
        FreeSpace 146119
        TotalSize 466938
    D - not ready
    MAYBE u can help me
    Oct 2005
    666th portal
    try avstodvd
  3. but in avstodvd i cant set "ntsc-film" mean 23.9...fps
    Oct 2005
    666th portal
    dvdflick hasn't been updated in a couple years. if it doesn't work, you need to use a different tool.
    Feb 2011
    New Zealand
    Just wondering, when you were at the Project setting - Burning did you tick the "Burn project to disc"? Just untick everything in there and make the leave the output file as VIDEO_TS folder. Then just burn it onto your disc manually. DVDflick's burning program doesn't seem to work properly.
    Edit: There's a bug in the newest version of DVDflick(Version 1.3.0.7). I use that program too and I kept on getting that error before. Luckily I found this thread here: http://forum.videohelp.com/threads/334152-Repeated-burning-error-with-dvd-flick-%28
    So I downloaded the previous version(ver. 1.3.0.6) and didn't encounter this problem anymore.
  6. Code:
    DVD Flick error log
    Windows 6.1 build 7601 Service Pack 1
    *** Project info
    EncodeProf 2
    Threads 4
    OverScan 0, 3
    TargetRate 0
    TargetFormat 0
    TargetSize 4
    CreateISO 0
    CustRate 0
    EnableBurn 1
    EraseRW 1
    HalfRes 0
    LoopPlayb 0
    AutoPlayMenu 1
    MenuTemplt Plasma Sphere
    VolumeMod 100
    WhenPlayed 3
    *** Warnings given
    EnsureEmptyDiscInserted |
    *** Titles
    0 - Kung Fu Panda
        ChaptCount -1
        ChaptInt 7
        ChaptSource 1
        TargetAR 1
        ThumbIndex 552
    1 - Kung Fu Panda 2
        ChaptCount -1
        ChaptInt 7
        ChaptSource 1
        TargetAR 1
        ThumbIndex 520
    *** Project sources
        D:\Movies\Kung Fu Panda 2.avi
        Stream 0 (2)
            Dur 5202.32
            StartT 0
            Compr mpeg4
            BitR 0
            640x272 25 FPS
            PAR 1
            SAR 2.352941
        Stream 1 (1)
            Dur 5202.32
            StartT 0
            Compr mp3
            BitR 32
            Chnnls 2
            SRate 48000
            Delay -160
        D:\Movies\Kung Fu Panda.avi
        Stream 0 (2)
            Dur 5519.01
            StartT 0
            Compr mpeg4
            BitR 0
            700x292 23.976 FPS
            PAR 1
            SAR 2.39726
        Stream 1 (1)
            Dur 5519.01
            StartT 0
            Compr mp3
            BitR 128
            Chnnls 2
            SRate 48000
            Delay -160
    *** dvdflick.log
    11:11:03 AM: DVD Flick 1.3.0.7 build 738
    11:11:03 AM: Calculating stream sizes...
    11:11:03 AM:     Disc space used : 4495852 KB
    11:11:03 AM:     Average bitrate : 3043 Kbit/s
    11:11:03 AM:     Total duration  : 2:58:41 hours
    11:11:03 AM: 2 title(s).
    11:11:03 AM: Using Normal encoding profile.
    11:11:03 AM: PAL target format.
    11:11:03 AM: CPU:        Intel(R) Core(TM) i5-2410M CPU @ 2.30GHz
    11:11:03 AM: Threadcount: 4
    11:11:03 AM: Encoding video...
    11:11:03 AM:     Title 0, source 0
    11:11:03 AM:         Source         : D:\Movies\Kung Fu Panda.avi
    11:11:03 AM:         Properties     : 700x292, 2.4:1, 23.976 FPS, mpeg4, 5519.01 seconds
    11:11:03 AM:         Target BitRate : 3043 Kbit\s
    11:11:03 AM:         Re-encoding
    11:11:03 AM:          -i "D:\Movies\Kung Fu Panda.avi" -vcodec mpeg2video -s 720x424 -padtop 76 -padbottom 76 -r 25 -g 12 -bufsize 1835008 -packetsize 2048 -muxrate 10080000 -aspect 16:9 -minrate 2993k -maxrate 2993k -b 2993k -preme 1 -precmp 2 -subcmp 8 -mbcmp 8 -cmp 1 -sws_flags lanczos+accurate_rnd -mbd 2 -sc_threshold -3000 -dc 8 -an -threads 4 -fflags +genpts -f mpeg2video -shortest -map 0:0 "C:\Users\Asus\Desktop\dvd\0.0.m2v"
    11:42:40 AM:     Title 1, source 0
    11:42:40 AM:         Source         : D:\Movies\Kung Fu Panda 2.avi
    11:42:40 AM:         Properties     : 640x272, 2.35:1, 25 FPS, mpeg4, 5202.32 seconds
    11:42:40 AM:         Target BitRate : 3043 Kbit\s
    11:42:40 AM:         Re-encoding
    11:42:40 AM:          -i "D:\Movies\Kung Fu Panda 2.avi" -vcodec mpeg2video -s 720x432 -padtop 72 -padbottom 72 -r 25 -g 12 -bufsize 1835008 -packetsize 2048 -muxrate 10080000 -aspect 16:9 -minrate 2993k -maxrate 2993k -b 2993k -preme 1 -precmp 2 -subcmp 8 -mbcmp 8 -cmp 1 -sws_flags lanczos+accurate_rnd -mbd 2 -sc_threshold -3000 -dc 8 -an -threads 4 -fflags +genpts -f mpeg2video -shortest -map 0:0 "C:\Users\Asus\Desktop\dvd\1.0.m2v"
    12:14:09 PM: Combining video sources...
    12:14:09 PM:         Concatenating video...
    12:14:09 PM: Encoding audio...
    12:14:09 PM:     Title 0, track 0, source 0 of 0
    12:14:09 PM:         Source     : D:\Movies\Kung Fu Panda.avi
    12:14:09 PM:         Properties : 2 channels, 48000 Hz, mp3, 5519.01 seconds
    12:14:09 PM:         Recompressing to 192 Kbit\s with 2 channel(s)
    12:14:09 PM:          -i "D:\Movies\Kung Fu Panda.avi" -i "C:\Users\Asus\Desktop\dvd\0.0.m2v" -map 0:1:1:0 -acodec ac3 -ab 192k -ac 2 -ar 48000 -threads 4 -async 0 -shortest "C:\Users\Asus\Desktop\dvd\0.0.0.ac3"
    12:16:26 PM:         Fixing delay of -160 ms
    12:16:26 PM:         -start -160 "C:\Users\Asus\Desktop\dvd\0.0.0.ac3"
    12:16:28 PM:     Title 1, track 0, source 0 of 0
    12:16:28 PM:         Source     : D:\Movies\Kung Fu Panda 2.avi
    12:16:28 PM:         Properties : 2 channels, 48000 Hz, mp3, 5202.32 seconds
    12:16:28 PM:         Recompressing to 192 Kbit\s with 2 channel(s)
    12:16:28 PM:          -i "D:\Movies\Kung Fu Panda 2.avi" -i "C:\Users\Asus\Desktop\dvd\1.0.m2v" -map 0:1:1:0 -acodec ac3 -ab 192k -ac 2 -ar 48000 -threads 4 -async 0 -shortest "C:\Users\Asus\Desktop\dvd\1.0.0.ac3"
    12:18:21 PM:         Fixing delay of -160 ms
    12:18:21 PM:         -start -160 "C:\Users\Asus\Desktop\dvd\1.0.0.ac3"
    12:18:23 PM: Combining audio sources...
    12:18:23 PM:         Concatenating audio...
    12:18:23 PM:             Title 0, track 0
    12:18:23 PM:             Title 1, track 0
    12:18:23 PM: Combining sources...
    12:18:23 PM:         Multiplexing audio and video
    12:18:23 PM:             -f 8 --vbr -o "C:\Users\Asus\Desktop\dvd\title0.mpg" "C:\Users\Asus\Desktop\dvd\0.0.m2v"  "C:\Users\Asus\Desktop\dvd\0.0.ac3"
    12:22:58 PM:         Cleaning up...
    12:22:59 PM:             Title 1
    12:22:59 PM:             -f 8 --vbr -o "C:\Users\Asus\Desktop\dvd\title1.mpg" "C:\Users\Asus\Desktop\dvd\1.0.m2v"  "C:\Users\Asus\Desktop\dvd\1.0.ac3"
    12:28:17 PM:         Cleaning up...
    12:28:18 PM: Adding subtitles...
    12:28:18 PM:     Title 0, subtitle 0
    12:28:18 PM:         Source: D:\Movies\Subtitles\Kung Fu Panda.srt
    12:28:18 PM:         Generating images...
    12:28:18 PM:         Fixed 0 overlaps
    12:28:18 PM:         Fixed 0 short blocks
    12:29:00 PM:         Converting images...
    12:30:37 PM:         Generating XML...
    12:30:37 PM:         "C:\Program Files (x86)\DVD Flick\bin\spumux.exe" -s 0 -m dvd "C:\Users\Asus\Desktop\dvd\spumux_title0_sub0.xml" < "title0.mpg" 1> "title0.temp" 2> "spumux_title0_sub0.txt"
    12:34:23 PM:     Title 1, subtitle 0
    12:34:23 PM:         Source: D:\Movies\Subtitles\Kung Fu Panda 2.srt
    12:34:23 PM:         Generating images...
    12:34:23 PM:         Fixed 0 overlaps
    12:34:23 PM:         Fixed 0 short blocks
    12:34:56 PM:         Converting images...
    12:36:30 PM:         Generating XML...
    12:36:30 PM:         "C:\Program Files (x86)\DVD Flick\bin\spumux.exe" -s 0 -m dvd "C:\Users\Asus\Desktop\dvd\spumux_title1_sub0.xml" < "title1.mpg" 1> "title1.temp" 2> "spumux_title1_sub0.txt"
    12:40:43 PM: Authoring DVD...
    12:40:43 PM:     Opening menu template
    12:40:43 PM:     Generating menu images
    12:40:44 PM:     Generating menu files
    12:40:49 PM: 53 from dvdflick: File not found
    *** 0.0.0_log.txt
    192.000000
    Sampling Frec=48000
    TotalFrames=172460
    Bytesperframe= 768.0000
    Filesize=132449280
    FrameDuration= 32.0000
    Framespersecond= 31.2500
    Duration=01:31:58.720
    Channels mode=2/0: L+R
    LFE=LFE: Not present
    [Target info]
    StartFrame=5
    EndFrame=172459
    NotFixedDelay=  0.0000
    Duration=01:31:58.560
    ====== PROCESSING LOG ======================
    Seeking....
    Done.
    Processing....
    Number of written frames = 172455
    Number of Errors= 0
    *** 1.0.0_log.txt
    192.000000
    Sampling Frec=48000
    TotalFrames=162564
    Filesize=124849152
    Duration=01:26:42.048
    [Target info]
    StartFrame=5
    EndFrame=162563
    Duration=01:26:41.888
    Seeking....
    Done.
    Processing....
    Number of written frames = 162559
    Number of Errors= 0
    *** bmp2png.txt
    C:\Program Files (x86)\DVD Flick\bin\bmp2png.exe -X -0 -E "C:\Users\Asus\Desktop\dvd\rootmenu_b1.bmp" -O "C:\Users\Asus\Desktop\dvd\rootmenu_b1.png"
    Reading rootmenu_b1.bm
    Read OK rootmenu_b1.bm
    Writing rootmenu_b1.pn ..............................
    Writing rootmenu_b1.pn oooooooooooooooooooooooooooooo
    OK      rootmenu_b1.pn
    163kB time=5382.94 bitrate= 192.0kbits/s
    size=  126715kB time=5406.50 bitrate= 192.0kbits/s
    size=  127264kB time=5429.92 bitrate= 192.0kbits/s
    size=  127822kB time=5453.76 bitrate= 192.0kbits/s
    size=  128364kB time=5476.86 bitrate= 192.0kbits/s
    size=  128934kB time=5501.18 bitrate= 192.0kbits/s
    size=  129345kB time=5518.72 bitrate= 192.0kbits/s
    video:0kB audio:129345kB global headers:0kB muxing overhead 0.000000%
    *** ffmpeg_audio_title1_track0_source0.txt
    894kB time=5072.83 bitrate= 192.0kbits/s
    size=  119391kB time=5094.02 bitrate= 192.0kbits/s
    size=  119914kB time=5116.35 bitrate= 192.0kbits/s
    size=  120454kB time=5139.36 bitrate= 192.0kbits/s
    size=  120987kB time=5162.11 bitrate= 192.0kbits/s
    size=  121522kB time=5184.96 bitrate= 192.0kbits/s
    size=  121923kB time=5202.05 bitrate= 192.0kbits/s
    video:0kB audio:121923kB global headers:0kB muxing overhead 0.000000%
    *** ffmpeg_menu0_-1.txt
    ideo: png, rgb24, 720x576, 25 tbr, 25 tbn, 25 tbc
    Output #0, mpeg2video, to 'C:\Users\Asus\Desktop\dvd\rootmenu_0.m2v':
        Stream #0.0: Video: mpeg2video, yuv420p, 720x576 [PAR 16:15 DAR 4:3], q=1-4, 8000 kb/s, 90k tbn, 25 tbc
    Stream mapping:
      Stream #0.0 -> #0.0
    Press [q] to stop encoding
    frame=    4 fps=  3 q=1.0 Lsize=     112kB time=0.12 bitrate=7614.1kbits/s
    video:112kB audio:0kB global headers:0kB muxing overhead 0.000000%
    *** ffmpeg_menu1_-1.txt
    Output #0, mpeg2video, to 'C:\Users\Asus\Desktop\dvd\rootmenu_1.m2v':
    Stream mapping:
      Stream #0.0 -> #0.0
    frame=    4 fps=  0 q=1.0 Lsize=     100kB time=0.12 bitrate=6843.7kbits/s
    video:100kB audio:0kB global headers:0kB muxing overhead 0.000000%
    521kB time=5513.92 bitrate=2993.0kbits/s
    frame=137889 fps= 73 q=2.0 size= 2015089kB time=5515.52 bitrate=2992.9kbits/s
    frame=137923 fps= 73 q=2.0 size= 2015626kB time=5516.88 bitrate=2993.0kbits/s
    frame=137964 fps= 73 q=2.0 size= 2016185kB time=5518.52 bitrate=2992.9kbits/s
    frame=137975 fps= 73 q=2.0 Lsize= 2016346kB time=5518.96 bitrate=2992.9kbits/s
    video:2016346kB audio:0kB global headers:0kB muxing overhead 0.000000%
    *** ffmpeg_video_title1_source0.txt
    583kB time=5196.48 bitrate=2993.0kbits/s
    frame=129947 fps= 69 q=2.0 size= 1899023kB time=5197.84 bitrate=2992.9kbits/s
    frame=129987 fps= 69 q=2.0 size= 1899608kB time=5199.44 bitrate=2992.9kbits/s
    frame=130025 fps= 69 q=2.0 size= 1900163kB time=5200.96 bitrate=2992.9kbits/s
    frame=130058 fps= 69 q=2.0 Lsize= 1900645kB time=5202.28 bitrate=2992.9kbits/s
    video:1900645kB audio:0kB global headers:0kB muxing overhead 0.000000%
    *** mplex_menu0_-1.txt
    ize 17652 bytes
       INFO: [] No. B Frames    :        0 avg. size     0 bytes
       INFO: [] Average bit-rate :  5710400 bits/sec
       INFO: [] Peak bit-rate    :        0  bits/sec
       INFO: [] BUFFERING min 2147483647 Buf max 1
       INFO: [] AUDIO_STATISTICS: bd
       INFO: [] Audio stream length 39424 bytes.
       INFO: [] Frames         :       77
       INFO: [] BUFFERING stream too short for useful statistics
       INFO: [] MUX STATUS: no under-runs detected.
    *** mplex_menu1_-1.txt
    s
       INFO: [] Average bit-rate :  5132800 bits/sec
    *** mplex_title0.txt
     :   126407 avg. size 13262 bytes
       INFO: [] Average bit-rate :  2992800 bits/sec
       INFO: [] Peak bit-rate    : 11856000  bits/sec
       INFO: [] BUFFERING min 15 Buf max 134306
       INFO: [] Audio stream length 132445440 bytes.
       INFO: [] Frames         :   172455
       INFO: [] BUFFERING min 67 Buf max 2371
    *** mplex_title1.txt
     :   119141 avg. size 13560 bytes
       INFO: [] Peak bit-rate    :  6884400  bits/sec
       INFO: [] Audio stream length 124845312 bytes.
       INFO: [] Frames         :   162559
       INFO: [] BUFFERING min 67 Buf max 2851
    *** spumux_menu0_-1.txt
    DVDAuthor::spumux, version 0.6.14-GfD.
    Build options: gnugetopt iconv freetype
    Send bugs to <gfd@boraxsoft.de>
    STAT: 0:00:00.000
    INFO: PNG had 2 colors
    INFO: Constructing blank img
    INFO: Pickbuttongroups, success with 1 groups, useimg=1
    INFO: Found EOF in .sub file.
    INFO: Max_sub_size=160
    INFO: 1 subtitles added, 0 subtitles skipped, stream: 32, offset: 0.16
    *** spumux_title0_sub0.txt
    cting blank hlt
    INFO: Constructing blank sel
    STAT: 1:25:28.483
    INFO: PNG had 4 colors
    INFO: Constructing blank hlt
    STAT: 1:25:33.154
    STAT: 1:30:36.646
    INFO: 978 subtitles added, 0 subtitles skipped, stream: 32, offset: 0.16
    *** spumux_title1_sub0.txt
    cting blank hlt
    STAT: 1:17:03.967
    STAT: 1:17:38.967
    STAT: 1:26:41.246
    INFO: 876 subtitles added, 0 subtitles skipped, stream: 32, offset: 0.16
        0.0.0_log.txt	487
        1.0.0_log.txt	487
        bmp2png.txt	332
        dvdflick.log	5359
        errorlog.txt	23686
        ffmpeg_audio_title0_track0_source0.txt	17020
        ffmpeg_audio_title1_track0_source0.txt	14571
        ffmpeg_menu0_-1.txt	1813
        ffmpeg_menu1_-1.txt	1813
        ffmpeg_video_title0_source0.txt	305353
        ffmpeg_video_title1_source0.txt	303318
        mplex_menu0_-1.txt	2809
        mplex_menu1_-1.txt	2823
        mplex_title0.txt	2723
        mplex_title1.txt	2723
        rootmenu_0.xml	357
        rootmenu_0d.mpg	155648
        rootmenu_1.mpg	126976
        rootmenu_1.xml	413
        rootmenu_b0.png	1246796
        rootmenu_b1.png	1246796
        rootmenu_h0.png	416817
        rootmenu_h1.png	416817
        rootmenu_s0.png	416817
        rootmenu_s1.png	416817
        spumux.bat	242
        spumux_menu0_-1.txt	386
        spumux_title0_sub0.txt	98135
        spumux_title0_sub0.xml	97590
        spumux_title1_sub0.txt	88055
        spumux_title1_sub0.xml	87301
        title0.mpg	2261125120
        title1.mpg	2131828736
    *** Drives
        C - Wong Cheng - 2
        FS NTFS
        AvailSpace 14017
        FreeSpace 14017
        TotalSize 200042
        D - Data - 2
        FS NTFS
        AvailSpace 12704
        FreeSpace 12704
        TotalSize 250395
    E - not ready
    G - not ready
    Q - not ready
  7. Mod Neophyte Super Moderator redwudz's Avatar
    USA
    Benwong1997, I had moved your post to a new thread here as you suggested: http://forum.videohelp.com/threads/356740-DVD-FLICK-error
  8. Member DB83's Avatar
    Jul 2007
    I would still proceed with avstodvd.
    For one thing the program is supported by the author within these forums. If something does not work for you, the author can usually put you in the right direction.
    ntsc film. Did you check the avisynth preferences? There is a checkbox for PAL speedup from ntsc film.
