#!/bin/sh
## ts2avi version 1.03 (01/11/2012) freeware by robert_maul@hotmail.com
## translate *.ts to *.avi (XviD) (works well with avidemux editor)
## ALERT: Version 1.02 broken by WinFF Version 1.4.0 (see notes below)
## this script will break again with the next version of WinFF
## This script runs on Windows using MinGW Shell aka Msys (Minimal Gnu on Windows)
## which is downloaded from sourceforge.net (cygwin has no uninstall! too messy!)
## since i started using MinGW i don't bother with Ubuntu any more.
## I added this script to my c:\users\robert\bin directory and
## that directory to the end of the system PATH variable
JAVA_HOME="/c/Program Files/Java/jre7/bin" # 64 bit java install
java="$JAVA_HOME/java"
projectx="/c/Project-X_0.91.0/ProjectX.jar"
FFMPEG_HOME="/c/Program Files (x86)/WinFF" # 32 bit (WinFF)
#FFMPEG_HOME="/c/AutoFF0998_Full_win" # 32 bit (AutoFF)
ffmpeg="$FFMPEG_HOME/ffmpeg"
AVIDEMUX_HOME="/c/Program Files/Avidemux 2.5"
avidemux="$AVIDEMUX_HOME/avidemux2_cli" # 64 bit command line version
## download locations: (i use 64 bit when available on my 64 bit machines)
## java: http://download.oracle.com/otn-pub/j...indows-x64.exe
## project-x: http://sourceforge.net/projects/proj...urce=directory
## avidemux: http://avidemux.sourceforge.net/ (choose command line when installing)
## ffmpeg: http://www.videohelp.com/tools/ffmpeg (then choose AutoFF link)
## or
## ffmpeg: http://www.winff.org/html_new/downloads.html
## email me suggestions for stable 64 bit version of ffmpeg that is easy to install.
## of course it would be nice if you tested it with this script before emailing me.
## Changes for 1.01: adjusted numbers for -wide2full option
## ffmpeg docs for -cropleft and -cropright very confusing.
## only took me about 1 year of tying different things to figure this out!
## Changes for 1.02: added -full2wide option for non HD station airing widescreen
## video (tiny widescreen rectangle in the middle of widescreen monitor)
## adjusted numbers for -full option so no resizing happens, (faster translation)
## Changes for 1.03: This script was broken with WinFF version 1.4.0 (works with WinFF 1.3.1)
## I don't know why the ffmpeg command line option changed but I have attempted temp fix
## Old Linux based notes:
## Ubuntu Linux version depends on project-x, winff and
## libavcodec-unstripped-52 # the name of this lib may vary but it contains XviD
## all found in ubuntu 10.10 synaptic repositories
## also depends on avidemux2_cli listed as avidemux-cli in rep
## i have a haupaugge capture card that creates the *.ts files
## i am currently looking for a better card since the WinTV
## software that comes with it crashes all time with the 2250
## so i had to yank it run with my old 1600 card only.
## UPDATE: WinTV 2.4 has not crashed on me yet.
## I imagine that this script could be adapted to convert the
## video files created with other brands of cards. suggestions
## for new cards greatly appreciated
## windows users can install ubuntu on there windows box quite
## easily using virtualbox 4.x and ubuntu.10.10 ... i found it
## easier than trying to rewrite this script in a windows script
## virtualbox lets you run windows and ubuntu linux at the same time
## my next project is to write a cron script that will run this
## this script automattically and delete the large ts and m2v
## files and leave just the *.avi and *.ac3 files that need to
## be merged before editing. so as the large ts files are
## created they can be tranlated to xvid unattended
## as of version 4.0 of virtualbox it is easy to share folders
## between the host (windows) and guest (ubuntu) machine provided
## that the share is not on the C: drive (permissions problems)
## note: the final *.editing.avi files created by this script will
## be larger when run through project-x, you can get away without
## running project-x if the input files have no bad data.
## bad data is usually weather or signal strength dependent.
## step 1 (automated)
## use Project-X to throw out any bad data and sync video and audi0
## with ProjectX (free download at sourcforge.net)
## for each ts file create a directory and move the file there.
## then demux the file creating the m2v (video) and ac3 (sound)
## The Project-X command line method was found in the ProjectX
## source ReadMe.txt file
## step 2 (automated)
## create avi file using ffmpeg (download winff and ffmpeg included)
## translate the m2v (video only) file to an avi (XviD) file
## the ffmpeg options used here were found by running winff and
## choosing: "Display CMD Line" under the options menu
## step 3 (automated) avidemux command line is run to put the *.avi
## and *.ac3 (audio) files together to create the *.editing.avi
## step 4 (manual)
## edit out commercials with avidemux and save that file as:
## *.done.avi
arg=$1
crop=""
if [ $arg = "-wide" ]; then
dim=704x384 # Winff default value used in case user wants to run 2-pass on
asp=16:9 # final edited *.done.avi file using WinFF (might make it smaller)
echo running with widescreen $asp aspect ratio $dim resolution
else
if [ $arg = "-wide720p" ]; then # disk space is getting cheaper so save quality
dim=1320x720 # 16/9=x/720 solve for x=1320
asp=16:9 # 720p just means vertical resolution is 720
echo running with wide screen 16:9 aspect ratio 720p resolution
else
if [ $arg = "-wide2full" ]; then # for HD station with full screen video
echo running with wide to full screen cropping to 4:3 aspect ratio
asp=4:3 # assuming the mpeg-2 file is 1980x1080 1980/16=x/4 solve for x=495
crop=" -cropleft 246 -cropright 246 " # 495/2~=246 (must crop in even numbers)
# 246 + 246 + 640 = 1132 (add back what was cropped off to arrive at 640x480)
dim=1132x480 # cropping happens before resizing but it also affects the
# resolution after resizing so it must be added back (very weird)
else
if [ $arg = "-full2wide" ]; then # for non HD station with wide screen video
echo running with full to wide screen cropping to 16:9 aspect ratio
asp=16:9 # assuming the mpeg-2 file is 704x480 704/16=x/9 solve for x=396
crop=" -croptop 42 -cropbottom 42 " # 480-396=84 84/2=42
dim=704x396 # no resizing, just cropping
else
if [ $arg = "-full" ]; then
dim=704x480 # no resizing = faster translation
asp=4:3
echo running with fullcreen 4:3 aspect ratio $dim resolution
else
echo args must be: "-wide", "-wide720p", "-wide2full", "-full2wide" or "-full"
exit 1
fi
fi
fi
fi
fi
## do steps 1, 2 and 3 for all files in list
list=`ls *.ts`
for fn in $list ; do
dir=`basename $fn .ts`
if [ ! -d $dir ]; then
mkdir $dir
fi
mv $fn $dir
cd $dir
dirpath=`pwd`
avi="$dirpath/$dir.avi"
m2v="$dirpath/$dir.m2v"
if [ ! -f $m2v ]; then
"$java" -Djava.awt.headless=true -jar "$projectx" -demux $fn
fi
if [ ! -f "$avi" ]; then
if [ -f "$m2v" ]; then
"$ffmpeg" -version >& tmp # WinFF 1.4.0 changed cmd line options for ffmpeg
ffmpeg_version=`head -1 tmp | awk '{print $2}'`
echo $ffmpeg_version
if [ $ffmpeg_version = "N-34294-g0bc5677" ]; then # it's Winff 1.4.0
"$ffmpeg" -y -i $m2v -f avi -r 29.97 -vcodec libxvid -vtag XVID -s $dim \
-aspect $asp -maxrate 1800k -b 1500k -qmin 3 -qmax 5 -bufsize 4096 \
-mbd 2 -bf 2 -acodec libmp3lame -ar 48000 -ab 128k -ac 2 $crop "$avi"
else # WinFF version 1.3.1 and previous
"$ffmpeg" -i $m2v -f avi -r 29.97 -vcodec libxvid -vtag XVID -s $dim \
-mbd 2 -bf 2 -flags +4mv -trellis -aic -cmp 2 -subcmp 2 -g 300 \
fi
fi
fi
if [ -f "$avi" ]; then # find the largest ac3 file and join it to the avi file
maxsize=0 # the smaller file is in mono and has snaps, crackles and pops
ac3list=`ls *.ac3`
for f in $ac3list ; do
size=`ls -la $f | awk '{ print $5 }' `
if [ $size -gt $maxsize ]; then
ac3=$f
maxsize=$size
fi
done
"$avidemux" --load "$avi" --external-ac3 "$ac3" --save "$dir.editing.avi" <<EOF
y
EOF
fi
cd ..
done
robertmaul: Please stop dig up old threads. And I moved your post to a new thread.
this script works on both windows and ubuntu linux
there is an indented version here: http://www.avidemux.org/smf/index.php?topic=10028.0Last edited by robertmaul; 2nd Dec 2011 at 00:15.
hauppauge 1212 and wintv extend
By tkolt in forum Media Center PC / MediaCentersReplies: 0Last Post: 18th Nov 2011, 18:56 -
How can I convert and edit Hauppauge WinTV .ts files to make a DVD?
By mgreen10 in forum Video ConversionReplies: 14Last Post: 6th Nov 2011, 21:52 -
Hauppauge WinTV-PVR 250
By thatsgame1 in forum Newbie / General discussionsReplies: 5Last Post: 22nd Jun 2011, 06:54 -
Hauppauge WinTV-HVR-950Q
By mauiwowi in forum CapturingReplies: 1Last Post: 28th Aug 2009, 21:43 -
Hauppauge WinTV PVR 250
By kenmo in forum ComputerReplies: 10Last Post: 28th Apr 2009, 13:21
Statistics
Newest guides
Latest tool updates
New media comments
