I recently bought an LG BE12LU38 external Blu-ray rewriter. I have it connected to my PC using the eSATA interface. All of my BR rips come out extremely choppy, DVD is fine. I noticed, after buying it, that the system requirements call for a 3.2GHz or higher processor. The CPU on my PC is an AMD Sempron LE-1300, which is only 2.3 GHZ. Could this be my problem? I have tried using MakeMKV and DVDFab to rip the BRs to my PC. It seems I have the latest firmware version for the optical drive, so I'm at a loss as to what the problem may be.
Is ther a primer, of sorts, for BR ripping I can read somewhere?
Results 1 to 16 of 16
Could the processor affect the rip itself? I copied one of the mkv files to my NAS and played over my network and that was choppy too, so it seems that the problem is at the rip stage, I'm thinking.
The NAS is plugged directly into my 2-Wire gateway. And actually it is my DVD player, LG BD590, hooked up to the network that I was using to try and view the mkv over the network. The BD590 is connected to a switch, which is connected to the back of my AT&T box. I can try a different format, like mp4, I don't need to have the file be mkv.
I was thinking this is a problem with my PC, not my network. The BD590 is wired to the network.
Your computer doesn't have to be fast to rip. Even if it takes a month the resulting file will still be fine.
I've seen some players have problems playing Blu-ray rips over 100 Mb Ethernet. Usually only at bitrate peaks though. 10 Mb Ethernet isn't fast enough unless the rips are reencoded with a low bitrate. Does your switch indicate the connection speed? Maybe with different color LEDs? -
The switch is connected at 100Mbps - DGS-2205, amber LEDs on Speed LEDs. So I still think this is a rip or a conversion problem. I will try to use Ripbot and see how that does.
Here is all I have to go on for the specs on the DVD player:
Video Files
Available resolution size: 1920 x 1080 (W x H) pixels
Playable subtitle: SubRip (.srt / .txt), SAMI (.smi), SubStation Alpha (.ssa/.txt), MicroDVD (.sub/.txt), VobSub (.sub), SubViewer 1.0 (.sub),
SubViewer 2.0 (.sub/.txt), TMPlayer (.txt), DVD Subtitle System (.txt)
• VobSub (.sub) is not available in the
[Home Link] feature.
Playable Codec format: “DIVX3.xx”, “DIVX4.xx”, “DIVX5.xx”, “XVID”, “DIVX6.xx” (Standard playback only), H.264/MPEG-4 AVC, MPEG1 SS,
MPEG2 PS, MPEG2 TS Playable Audio format: “Dolby Digital”, “DTS”, “MP3”, “WMA”, “AAC”, “AC3”
• Not all the WMA and AAC Audio format is compatible with this unit.
Sampling frequency: within 32-48KHz (WMA), within 16-48KHz (MP3)
Bit rate: within 20-320Kbps (WMA), within 32-320Kbps (MP3)
NOTE
• HD video files contained on the CD or USB 1.0/1.1 may not played properly. BD, DVD or USB 2.0 are recommended to play back HD video
files.
• This player supports H.264/MPEG-4 AVC profile Main, High at Level 4.1. For a file with higher level, the warning message will appear on the screen.
• This player does not support files that are recorded with GMC*1 or Qpel*2. Those are video encoding techniques in MPEG4 standard, like DivX or XVID have.
*1 GMC – Global Motion Compensation
*2 Qpel – Quarter pixel -
I think everything is ok now. I used ripbot to convert to mp4. On my PC, it plays sorta slow motion, but the video is in sync with the audio, and no cutting out. On my network it plays smooth. I will do some further testing as this test was only the first chapter of a movie, but I am optimistic. Thanks for all the replies, and I apologize if I wasted anyone's time.
Problem with DVDFab and Blu-Ray rips looking washed out.
By billw6560 in forum Blu-ray RippingReplies: 18Last Post: 5th Apr 2012, 17:39 -
Blu-ray rips jerky? What program to use?
By Mavrick in forum Blu-ray RippingReplies: 2Last Post: 30th Jan 2012, 21:07 -
Trying to get LPCM to work in Blu-Ray rips
By wannabeme in forum Blu-ray RippingReplies: 0Last Post: 10th Apr 2010, 21:28 -
DVD and Blu-Ray rips
By ldoodle in forum Blu-ray RippingReplies: 2Last Post: 22nd Sep 2009, 22:11 -
Blu-Ray Player Prices coming down
By tmw in forum DVD & Blu-ray PlayersReplies: 3Last Post: 17th Nov 2008, 10:18
