Hi
I have Avatar movie in SBS mkv format and converted .srt into .sup using 3D subtitler. After muxing them using mkvmerge I can see the subtitles harcoded on PC but not on my LG 3D TV via DLNA. What am I doing wrong and how to fix this?
Huh??
Subs that are MUXED into a file are NOT hardcoded at all. Only when subs become become part of the video are they truly hardcoded. What you've got there are just sub streams muxed along with the muxed video & audio streams.
So, the question really is: does your LG TV support muxed subs?
Every video device supports hardcoded subs (as long as they support the video), because by that point they are one with the video.
Why don't you tell us further info about your player/server software, you DNLA setup, your TV model, etc...
Scott -
My TV ls LG LW5600 , DLNA Server is Buffalo NAS LS-VL607 LS-V2.0TL. connected to router WHR-HP-G300N .
While LG TV does support avi mp4 and mkv etc but I dont think it supports muxed subtitles. subtitles are probably not supported by DLNA media server either. So in this what is the best way to hardcode the subs? -
you might be better off getting a device that supports subs if you really need them. an lg bluray player like the bd670 works nicely with a nas.
otherwise you will have to re-encode the video to burn in the subs permanently. the quality of the video will be reduced.--
Step 1:
Use 3D Subtitler
Create 3d subtitle *.sup file
Duration ~ 5 minutes (depends cpu)
Step 2:
USE Tsmuxer
Transform movie *.mkv to *.ts
Duration ~ 15 minutes (depends cpu)
Step 3:
USE RipBot264
Transform movie *.ts to *.mkv again
Now in option use "Permanent subtitle" and use *.sup file from first step.
CQ = 18 (Best quality)
Duration ~ 4 hours (depends cpu) -
hardcoding subs
By zammil in forum SubtitleReplies: 27Last Post: 24th Sep 2010, 05:10 -
help hardcoding subs to mkv
By striker9 in forum SubtitleReplies: 14Last Post: 20th Aug 2010, 07:40 -
AutoGK not hardcoding subtitles?
By vangelon in forum DVD RippingReplies: 9Last Post: 19th Nov 2009, 06:48 -
By vangelon in forum Video ConversionReplies: 1Last Post: 18th Nov 2009, 06:56 -
hardcoding subtitles (.mkv)
By LukeGuldan in forum Video ConversionReplies: 5Last Post: 15th Nov 2009, 11:27
For me, work this
I am
, but I go direct mkv to mkv and my HT LG play 3D sbs subtitle correct??
