Please consider supporting us by disabling your ad blocker or buy PlayOn (record Netflix) :)
Results 1 to 23 of 23
  1. I've been using DVD Fab but it's expensive so i use the free version. Anyway i bought a regular Blu-Ray player Thursday and sometime in the next few monthsw i might buy an external Blu-Ray Burner and as Fab is expensive to buy,and as DVD Shrink won't read the Blu-Ray files, I was wondering if there was a DVD Shrink like program to shrink the file size of Blu-Ray so it can fit a 25 GB Disc. If there is nothing like that, no problem. Just wondered. please respond as soon as you can. Thanks.
  2. BDRebuilder and AVCHDCoder come to mind. But neither can decrypt as DVDShrink can, even though it's outdated and can't handle remotely recent copy protections.
    DVDFabHDDecrypter is the only free Blu-Ray decrypter, but updates lag behind the pay version.
    Pull! Bang! Darn!
  3. well i don't think shrink can read blu-ray files. if it can,no biggie. i have tried using dvd shrink to decrypt and it won't do anything. if i can';t use dvd fab to decrypt, i use dvd decrypter. they don't update either but it does work.
  4. No no, obviously DVDShrink is for DVDs only, otherwise you wouldn't be asking about a *similar* program for Blu-Ray, would you? Similar as in it can remove unwanted audio/subtitle tracks or do a movie only backup.
    Pull! Bang! Darn!
  5. ok well i assume these 2 programs you linked are free?doesn't indicate you pay,but just thought i'd ask.
  6. Originally Posted by Bamahusker View Post
    Yes, they are both Freeware (also indicated on the download pages post #2 linked to).
  7. ok n0ow i have a question regarding Blu Ray External Burners. Why after all this time you still see no externals selling in stores? Amazon is about the only one i know of and most are 200 or more.
    Nov 2005
    Use DVDFabHDDecrypter to rip the BR's to the HD and BDrebuilder to shrink em...or AVCHDcoder...Multiavchd can do it also. None of these apps is all-in-one like Dvdshrink.
    For external BR drives go here...and another one here.
    You have to remember, BR drives pour out gobs of mb's in terms of data and most external stuff is still USB 2.0...when they get more USB 3.0 ext. out there it'll be more popular but USB 2.0 won't cut it at high speeds. You could probably get away with a slow burn but it would be close.
  9. Member dragonkeeper's Avatar
    Jul 2003
    USB 2,0 is the most popular format for external devices but it is not fast enough to stream the amount of data for a BD burn. USB. Although firewire 800 can sustain the speed need to burn bd I suspect manufactures did not create Firewire BD drives as the drive market is primarily dominated by USB.
    Murphy's law taught me everything I know.
  10. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    Just digging up old threads to spam some crapware that can't even spell Blu for Bluray correctly....
    LOL!!!
  11. I'd suggest MakeMKV and DVDx 4.1
    One may say I'm spamming...
    Aug 2006
    The above poster is the author of DVD x4.1 and promotes his own software in these forums because nobody else here recommends it. His paid software depends on other paid software purchased separately, like MakeMKV, to do the actual Blu-ray decryption. If I recall correctly, his software is subscription based.
    There are lower-cost alternatives. MakeMKV can decrypt and convert to MKV on its own, and there is free software that converts from MKV to other formats. If someone already has AnyDVD HD or DVDFabHD Decrypter, BDRebuilder which is free works with Blu-Ray files that are already decrypted.
  13. Banned
    Jun 2004
    Really ?
    Did you join just to dig up a 3 year old thread to post 3 times,
    Try blue-cloner
    ERRRRRR!!!!
    Feb 2008
    India
    we are in process sooner or later.
    Dec 2013
    California
    MakeMKV sound like best choice to rip... But then i have to convert to mp4 using something like HandBrake.
    is there anything like that or DVDShrink 3.2.00.15 for Blue Ray to rip directly to an MP4 - with AAC or PCM to edit with on Avid System as an mp4 AMA clip?
  16. Originally Posted by theGuruWithin View Post
    Maybe:
    Like "BR-Shrink" or "BR-DVD-Cloner" but is better not to depend on any "all-in-One" garbage.
    1.- AnyDVD
    2.- DVDFab-9xxxx is all-in-one, but if you use it only for ripping: It's your best bet.
    3.- MakeMKV
    Dec 2013
    California
    Sounds like MakeMKV then convert to mp4/ACC with HandBreak would give best quality...
  18. Member
    Nov 2003
    West Texas
    Depends on what size copy you want. Best quality while compressing will be achieved using a decrypter to rip the Blu-ray (AnyDVD HD or MakeMKV in Backup mode), then compress to fit a single layer BD-R using BD Rebuilder. Many people want smaller copies than 23gb however.
  19. Rancid User ron spencer's Avatar
    May 2005
    Ish-ka-bibble
    are these rental videos or purchased ones?
    'Do I look absolutely divine and regal, and yet at the same time very pretty and rather accessible?' - Queenie
  20. Banned
    Jun 2004
    Seriously ?!?!?!?!
    The original post is like 4 years old, and the member who just resurrected it in no way said anything i see that would even suggest he is trying to rip and copy rented blurays......
    So you must just be trolling.......
  21. Rancid User ron spencer's Avatar
    May 2005
    Ish-ka-bibble
    Seriously ?!?!?!?!
    I was just asking....stop tripping on molly....
  22. Originally Posted by theGuruWithin View Post
    I use Makemkv to rip the BR to mkv as 1:1
    ...then shrink the mkv as mkv with handbreak
    ...and finally converted to mp4.
    ...or convert to AVCHD & burn "The babies" BR files (.m2ts) in to a DVD-R as HD, with a regular DVD burner or BR burner (wherever fit your needs).
    Just my $0.02
  23. Banned
    Jun 2004
    And I was just curious as to what difference it would make ?
    Other than to start the "it is against the forum rules and the law to copy rented DVD's or Blurays" ?!?!
    Seeing as there was no mention of it anywhere until you mentioned it....
