  1. Hey all,
    So I want to put an anime series on my Ipod. I know how to convert the necessary files, but the issue is the audio track. When I watch the show in VLC, I have the option to switch the audio track from Japanese to English. When I do convert the episodes, they only come out in Japanese and not English. Does anyone have any ideas on what I should do or what programs will help me? Thanks in advance.
    p.s. Im currently using videora ipod converter.
  2. One way is to remux it and remove the other audio tracks before using your converter software. This way it has no choice but to use English
    If they are mp4, then use yamb. If they are mkv, then use mkvtoolnix. If they are AVI, then use avi-mux gui
  3. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    I don't use Videora, but I see at its site that it has profiles where you can set options for conversion. Look at the audio options and see if there is a track selection.
  4. Member dragonkeeper's Avatar
    Jul 2003
    I believe that's your problem Videora. Do yo want to leave both audio tracks in tact or use only the English track?
    What format are you converting to mp4, mkv, avi? Are you converting the audio as well or leaving it alone?
    Murphy's law taught me everything I know.
