Please consider supporting us by disabling your ad blocker or buy PlayOn (record Netflix) :)
Results 1 to 9 of 9
  1. How to convert an .avi or .mkv or .mp4 file to mpgav for burning to a VCD in my computer's dvd writer?
    will I loss quality?Will the size increases?..Please suggest a way...Thank you.
    Use for example avi2dvd. And yes, you will lose quality. VCD is just 352x240/288 in video size/resolution.
  3. @Baldrick
    will it play in all stand alone dvd players with full screen effect?will this thing http://www.videohelp.com/oldguides/divxtovcd do my job? If I have a 700mb high quality dvdrip can I convert it to one VCD with loss of a little quality...? will the size increases ? or can I convert it to two VCD without lossing quality....
    Next thing is if I have a 1.4gb dvdrip can I burn it dvd to play in my home dvd player
    which is the format that accepted by all stand alone dvd players except .vob.
    Please reply to all my questions..
    Sincere thanks to Baldrick...
    Why not make a dvd if you are going to play it on a DVD PLAYER? Use then the free avstodvd, dvdflick or freemake video converter.
  5. ok thank you
    But I have one doubt...there is no thread regarding "avi2dvd using avstodvd" please give a link and one more to which format I convert avi to.. for using in local dvd players....thanks.
  6. What is the format of the DVDRip that you have?
    You can just use avi2dvd or dvdflick to convert many different format files to DVD. These tools will create the final folder (Video_TS, Audio_TS) for you to burn onto a blank DVD disc.
    Just click on avi2dvd or dvdflick and download them. No need to go for VCd format. That will reduce quality greatly, compared to DVD.
  7. I have to convert a 700mb axxo dvdrip in avi format to dvd ... will the size increase...if yes how much? which programme is more suitable..thanks.
  8. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Yes the size will increase.
    Yes nharikrishna already answered your question about which programs to use.
  9. Mod Neophyte Super Moderator redwudz's Avatar
    USA
    axxo dvdrip
    As in Warez? Please read our rules about Warez before posting. Video Help Rules
    Moderator redwudz
